Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Antennas and Associated Hardware > Scanner / Receiver Antennas
Scanner / Receiver Antennas - For discussion of any type of receiving antenna used by a scanner or receiver base, mobile or handheld.
  #21 (permalink)
Old 01-13-2018, 11:23 AM
I wouldn't bother with the PAR MON-3 design. Jeff Santee said his discone was a better choice.
https://www.radiobanter.com/antenna/...nd-d-130j.html
/Ubbe
  #22 (permalink)
Old 01-13-2018, 3:24 PM
Wink
/Ubbe
Thanks. I am going to pass on it now anyway as for it seems discontinued & unfindable on the web anywhere. One off the list it is.
I am going to start by purchasing the Larsen NMO 150/450/800 Antenna & attach it to a Nagoya GPK-01 Ground Plane Kit on my mast outside. I just discovered & heard about this wonderfully rated antenna by Larsen that everybody is raving about with its receiving & performance abilities which I definitely need especially in those 3 frequency ranges that I monitor on my digital scanner. I can get it with shipping for about $34.00 plus about $27.00 for the ground plane kit.
