Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Antennas and Associated Hardware > Scanner / Receiver Antennas
Scanner / Receiver Antennas - For discussion of any type of receiving antenna used by a scanner or receiver base, mobile or handheld.
Old 04-17-2018, 7:43 AM
Default Crushcraft pc904
Would the mentioned model in title be a Yagi? And would it work for a scanner ? Any info on the model antenna would be appreciated . Attached picture of antenna related to question would it be a good fit for the Bcd536hp?
Old 04-17-2018, 7:58 AM
popnokick's Avatar
Yes.... it's a Yagi directional gain antenna for the frequency range of 896-980 mHz as is printed on the boom. It will work for a scanner if what you want to receive is in that frequency range and in the direction it is pointed. For other frequencies on a scanner.... not very useful (if at all).
