Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Antennas and Associated Hardware > Scanner / Receiver Antennas
Scanner / Receiver Antennas - For discussion of any type of receiving antenna used by a scanner or receiver base, mobile or handheld.
Old 06-13-2018, 1:39 PM
SimpleSkye's Avatar
Default Largest Coax for Diamond D130
Anyone have a Diamond D130? What type of coax are you feeding it with?
I have TONS of LDF5 laying around; I suspect that with an N connector attached, it will be too large for the pipe the D130 has around the connector.
FWIW, I have an LNA I may end up using, which in that case I will need a jumper anyway so... moot point!
Old 06-13-2018, 1:51 PM
ocn29rsc's Avatar
Depends on how far of a run your going to make and what frequency your using. If i'm no
that is some pretty big cable your using.
Old 06-13-2018, 2:03 PM
SimpleSkye's Avatar
The runs are only like 25-30' - so I know it is WAY overkill. I just didn't want to have to buy coax / connectors if I could use what I already have laying around as surplus.
50 - 900 mHz routinely, it is going to be connected to an SDR.
Old 06-13-2018, 2:06 PM
ko6jw_2's Avatar
If you want to run large coax or heliax, I would suggest making a short stub from LMR400 or equivalent to get the connector out the bottom of the tube and then attach the larger coax. The D130 with an N connector should work fine.
Old 06-13-2018, 2:08 PM
SimpleSkye's Avatar
Cool - thanks! I was kinda thinking I may need to do that; good to see others are thinking the same thing ^_^.
Old 06-13-2018, 3:28 PM
If my memory is correct those came with a pigtail, or at least my many yearold one did when I bought it.
- never used it though -
SDS-100, BCD536,Hp2(e),HP-1(e)x2, BC780, BCD996t ,BCD996P2, BCD325P2, Pro 2005, 2006(x2), Pro34,VR500,AT803,R5000 and other RF capture devices
