Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Antennas and Associated Hardware > Scanner / Receiver Antennas
Scanner / Receiver Antennas - For discussion of any type of receiving antenna used by a scanner or receiver base, mobile or handheld.
Old 08-10-2018, 12:46 AM
llwade's Avatar
Default Distance between antennas
On top of a 20 foot pole, I have mounted a Panarama BS800 scanner antenna. ( 762-894 range ). I would like to attach a TV ( bow tie ) antenna, about 10 inches below the BS800. Will this create any receiving problems with the TV / scanner? thank you for your time
73s
LLWade
email: leroywade@mediacombb.net
BCD996XT, HP-1, BCD536HP, SDS100
Old 08-10-2018, 1:08 AM
SDRPlayer's Avatar
I think the rule of thumb is half wavelength distance at your lowest frequency, so no problem there.
"Life is a series of events designed to interrupt my SDR time"
Old 08-10-2018, 11:49 AM
jfr jfr is offline
These are both RX-only antennas? If so, you should be fine.
