And from most of us here welcome to RR and the hobby.
Thank you
The Diamond discone has a whip with two loading coils in it and I use it here in the house for short range stuff. I mounted mine on a mike stand
I have two Diamond discones and swear by them. A full-sized one on my antenna mast on the house, and the small Diamond discone
You are on the right track.
There is no magic involved in antenna design, it's all physics. The laws of physics can't be cheated by any antenna manufacturer, although there are plenty that want you to think they can.
Comparing like for like when looking at decibel number is important. Make sure you are comparing dBi to dBi or dBd to dBd.
So this has led me to focus on these 3 options:
A 'small' discone:
https://www.diamondantenna.net/d220.html
I don't know if it would be much different from their larger version, but since my aim is to use it indoors the larger one may be a bit much to handle (unless I could perhaps disguise it as a Christmas-tree and put it out on the balcony, where antennae are prohibited)
Or one of these 2 by DPDprod (DPDprod seems to be praised by several users on this forum)
A dedicated civ/mil airband antenna:
https://dpdproductions.com/collecti...tennas/products/air-omni-uhf-vhf-base-antenna
Or a similar, but with wider coverage, scanner-version, which seems to cover the civ/mil airband about the same:
https://dpdproductions.com/collecti...-antennas/products/omnix-scanner-base-antenna
I think the DPDprod antennae would be easier to set up indoors, since they mostly take up space in 2 dimensions, where the discone takes up space in 3 dimensions.
But I'm not sure if I'm missing something.
I looked inside it and run an SWR analyze on it.
The filters makes it unsuitable for the 300-400MHz range. Are you actually receiving anything in the mil-air range?
I saved your tech-directions so I can perhaps buy an extra one to take apart and experiment with
I am receiving the military control-center at around 309 MHz. It comes in at about the same strength as the civil control-center at around 123 MHz.
I don't know where either transmitter is located though, so I can't really evaluate if I should be able to receive it stronger than I do.
When I experimented with home-made dipoles (I even tried using a T-connector with 2 antennae, 1 tuned for civ, the other for mil), both centers were also received (comparably similar to what I get with the TV-'bunny', but with less power)
I have no real clue as to why the 'bunny' performs so well for me, but perhaps the filters built into it help in some non-trivial way with local radio-interference (which there is TONS of here
Computers, TVs, pulsating lights and all kinds of wifi and short-range-devices etc)
Get it outside, on the roof.
I can only dream of that in this place
I am at the bottom of a high-rise, surrounded by other high-rises.
There's a tiny balcony, but house-rules that no antenna may be put on it (and it's placed so low that people outside can literally just reach up an grab things on it. So I can't really disguise an antenna on it. On the higher floors I could probably have gotten away with putting one up, since up there it wouldn't be very visible from below)
