I've done a search and am more confused than ever.
I plan on putting a scanner antenna up and would like to confirm what I think I have read.
To ground my antenna, I should run a ground wire from the antenna to a ground rod about 2 ft away from the house. Then, run another ground wire from the ground rod to the service panel of the house. Is this correct? I understand that this is to provide two paths to discharge a lightening strike, yes?
Instead of grounding to the service panel, can I ground to say an outlet box, would that be the same?
Sorry to the neophite questions....
