Sorry to revive an ANCIENT thread but I didn't think I should start yet another new one.
I'm wondering if there is an easy way to modify this antenna so that it receives just a little better in the 154-156mhz range. Basically there are several conventional frequencies in this range that I would like to monitor that I can often receive but just not enough to comfortably monitor. I'm limited to keeping the antenna indoors. I have a very short cable run and have tried various cables, including a short run of LMR-400 and tried moving the antenna to various locations in the apartment. I believe the top elements are permanent but can obviously be trimmed. I know that there are 800mhz mods to the UHF elements. My knowledge of the science behind antennas is basically nil but I'm trying to learn. Sacrificing other bands is a chance I'm willing to take if it will improve the 154-156mhz performance.
Thanks!
The antenna is a 1/4 wave ground plane at VHF with a pair of 1/4 wave elements added to help with UHF reception.
Replacing one 1/4 wave antenna with another isn't likely to make any difference.
Same with trimming it for exactly 1/4 wavelength at 154-156MHz. For receiving, it just isn't that critical.
Upgrading coaxial cable is often an easy way to squeeze a bit of performance out of an antenna system, but in your case, the minimal length likely isn't going to make enough difference to notice.
Indoors it's kind of hard to fit a "gain" antenna in there. You could try, but a 5/8ths wave antenna is going to be about 47 inches long, and it'll still require the ground plane. Might be worth trying a 5/8th's wave NMO mount mobile antenna with the base station adapter kit. It's not going to be cheap and is only going to give you 3dB more gain, which may or may not make enough difference for you.
Of course you realize the core issue here is that you need to keep the antenna inside. That creates issues with shielding from building materials and local noise sources,
You could try a preamplifier, but I suspect that isn't going to help much. While it can increase signal strength, it'll also increase the interference from local noise sources.
Is there any way at all to get a stealth antenna outdoors?
