Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Antennas and Associated Hardware > Scanner / Receiver Antennas
Scanner / Receiver Antennas - For discussion of any type of receiving antenna used by a scanner or receiver base, mobile or handheld.
Old 08-12-2007, 9:22 PM
Default Looking for an antenna for 1090 Mhz
Have a Discone antenna that says it covers up to the 1200 Mhz band but when hooked up it doesn't seem to pick up any signal. I am running a SBS type receiver for aircraft.
http://www.airnavsystems.com/RadarBox/index.html
Any suggestions out there? The receiver has a small magnetic antenna, but my setup is in the basement and I need to put the antenna outside. The original plan was to use the discone but it doesn't seem to work so now working on plan "B'. Found a few antennas but nothing Canadian or US.
TIA
Steve
Old 08-12-2007, 10:26 PM
Silent Key
At 1090 MHz, you're talking HUGE losses in any significant length of Coax. I wouldn't try more than 50 feet of good coax at that frequency, considering the signals aren't that strong in the first place. RG8 at minimum, and probably a better grade of it, say, Belden 9913.
N6IMN - GMRS WQGJ903
Old 08-12-2007, 10:39 PM
GreatLakes's Avatar
Not Posting
This might help:
http://www.wimo.com/cgi-bin/verteile...l-radar_e.html
Old 08-13-2007, 8:59 PM
Thanks for the info gentlemen!
Steve
Old 08-14-2007, 11:51 PM
k9rzz's Avatar
At that freq. I'd go RG6 or better yet 1/2 inch hardline !
If you can make the majority of the run hardline, and use LMR400 for the flexible ends (antenna end and inside run), that would help.
