396T Antenna
Dubbin
Findlay Ohio
Pick up the radio shack 800 MHz antenna. It excels in the 800's and is a pretty good all around performer for the rest.
N4JNW
Irvine, KY
Actually, it depends on what you want to listen to.
While Dubbin', is correct, the RadioShack 800mhz antenna is an excellent performer for 800 mhz scanning. For anything 800 mhz, conventional, trunked, P25, it excels.
BUT, I've found it's about the SAME as the 396T's stock duckie on VHF Hi band (150-159 mhz)
For UHF (400-460 mhz) it's performance is also marginal, and for aircraft band, (118-137 mhz), it's pretty much deaf to the world.
If you want increased VHF and UHF and aircraft reception, I reccomend the Diamond RH77CA antenna. It is a bit lengthy, but it's a awesome performer for those bands. Where the RH77CA lacks, the RS800 excels, and where the RS800 lacks, the Diamond 77CA' excels.
k9swx
Champaign, IL
I just picked up the 800mhz antenna from RS today and it seems to be as advertised. Nice little antenna for $20. Thanks for the recommendation!
