antenex
policeMonitor
Michigan
would this rx good with my 396t?
mancow
N.E. Kansas
....depends what your 396 is tuned to.
If it extends past the picture then I would say Vhf.
DickH
policeMonitor said:
is this a vhf antenna?
also how long should a 800mhz antenna be
A 1/4 wavelength antenna at 850MHz is about 3-1/4" long.
SLWilson
Ohio
NMO attachment - mag mount...
From Antenex.....If you are wanting to listen to "mostly" 800MHz stuff, this is a good model. I have one for my Pro96 mounted on my car. It should fit your mag mount (standard NMO mount)...
Their website: http://www.antenex.com/index051206.htm
The model number for the antenna in the below picture:
TRAB821/18503 Black Housing 821-896 MHz - 1850-1990 MHz 858.5 MHz 1920 MHz 3 dB MEG 2.30” $60.00
Steve/KB8FAR :cool:
