bownasterm
- Joined
- Oct 28, 2007
- Messages
- 130
What would be the best 800mhz range antenna for picking up a system that is a good distance from my house (probably 10-12mi)
brandon said:It's about a 100 dollars but I think it is worth the extra cost for a dedicated antenna on that band.
bownasterm said:Well i have an out door antenna currently with about 24 feet of coax between the antenna and my scanner the antenna is not actually outdoors right now its up next to a window on the second floor of my house
the systems im monitoring are motorola and edacs trunking systems in the 800mhz range which im having troulble picking up anything that is beyond 5 miles around here
bownasterm said:I have about 20 feet of RG58A/U cable the 800mhz duck sticking out the window did improve the sound on the systems that i already can hear but the farther off ones were still choppy
Do you think if i got a pole or something and attached the sputnik to it and stuck that high up out the window it would bring all of the systems in better?
brandon said:I use an Antenex FG8246 (824-896 6DB omni) purchased from RadioOutfitter.com
bownasterm said:What cable would you recommend for 800mhz?
