I have a Kenwood TS-440AT with a diamond SX-200 external power/swr meter and an I-max 2000 10 meter antenna. The radio also has it's own power/swr meter built in. When I tune the antenna with the built in antenna tuner in the radio I get different swr readings on the internal and external meters. I always just went by the meter in the radio and had good results so I thought but decided to add the external meter figuring it would be a little more accurate and easier to see. I used a scrap piece of the same coax thats feeding the antenna to make the jumper to connect the external meter and its about 2 ft in length. I've double checked all connections on the antenna and jumper and everything is good and the antenna is well grounded.
So the question is which meter do I believe?
or...
Do I have an antenna or feed line problem?
Any advise appreciated.
or...
