hello, ive been searching for quite some time to find an antenna that will perform nicely in the 42mhz range, and i have found nothing! i was looking at antennas on ebay and i found this one, however it doesnt list a specific range, can you tell by looking at this page if this would make for a good low band antenna? if not, can you point me in the direction of one? i need it to connect to my pro 83 and 76, so a bnc "plug" is mandatory, i also need it to be magnet mounted on my car or just monuted on the scanner normally, and since this is gonna be on a scanner i dont need anything that can transmit, money does NOT matter, ill spend $30, ill spend $300, as long as i can find something that will perform awesome in the 42 mhz range, if it could include the 39mhz range that would be an added bonus, but isnt necessary by any means, thanks for your help
http://cgi.ebay.com/HUSTLER-MRM-MAG...yZ149988QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
