Hello All,
I recently purchased a Pro96 and the 800 Mhz antenna. It all works pretty good, but there seems to be some transmissions that don't quite make it. The solution? Better antenna! A yagi seems the answer and fairly simple to construct.....well, kinda simple. While thinking about cutting the elements and mounting on a suitable boom, I came upon a thought.
I wonder if this would work? For a receiving antenna, I can't see why not. Picture if you will, a yagi. A boom with the elements mounted perpendicular to the boom. Now mentally erase the boom and picture the elements floating in open space. Further image a suitable sized piece of rigid foamcore board into this mental picture. What if the elements were glued to the foamcore? Lightweight, no trying to drill holes and keeping them all square and centered along a centerline. Instead of fastening the elements perpendicularly to a boom, the elements are parallel to the flat surface of the foamcore. Laying out the centerline and element spacing would be so much easier on the foamcore; one centerline drawn on it and perpendicular lines drawn along the length of the centerline at the appropriate spacing. The wire elements would then be glued in position. The finished yagi would be then mounted on edge with the elements in a vertical orientation. I don't have the exact details for the drive element worked out along with attaching the coax, but I've got a couple of thoughts. I'm thinking of a folded dipole and reducing the 300 ohms to 75 ohms.
I simply don't see why this type of construction won't work. The weather forcast for us is a snow storm this weekend. Sounds like a good time to scrape up some bits and pieces I've got laying around and give the idea a try. Some pictures to post would be in order too.
I thought I would share my brainstorming. If it doesn't work, no biggie; it might cost me $2 to build.
Karl
Karl
