jonny290 said:
Borrow an old bottle of the lady's fingernail polish and dab on each joint after you screw in. It's strong enough that wind and random vibration won't break it loose, but if you need to disassemble it'll break free no problem.
Hmmmmm... Maybe if you want to lock down trimmers and such but, for something that has to be out in the weather and subject to assorted stresses and the like the products from "LockTite" and the other like companies are a much better source. "The Poor Man's `loctite'" (IE: fingernail polish) just really does not hold up all that well though one *may* get lucky now and then.
When I was running my repair shop we used to use fingernail polish more as a way of determining if a custome had gone inside and `tweaked' when we had told that doing so would void the warranty on the repair more than as a `lock' on any adjustments we'd done. When we actually needed to assure that an adjustment wouldn't `slip', `rattle', or otherwise end up `out of spec' we used to use a commercial `glyptal' type product that actually was slightly `rubbery' and would resist the movements that would usually cause the problem and still also let us `re-tweak' things if needed later on without endangering delicate `slugs' or other parts of the adjustable device. For something antenna radials and other elements, case and mounting screws, and other similar fastenings / fastener we would pretty much stick with the `loctite' type method. Never let us down.
Just an `Olde Fart's' 2¢ worth. YMMV {CHORTLE!}
