I have seemed to have had the worst luck with antennas. I live in Lexington, KY and monitor a lot of frequencies and also monitor a different counties frequencies when I'm at college. I typically monitor the Conv police frequencies which operate around 151MHZ i also monitor the 800MHZ trunked system (which is a lot harder to pick up). I also listen to the digital 430MHZ state police frequency (Their signal is so strong I'm not worried about this). I have had the standard rubber duck antenna which picked up alright (not very good in the dorm room surrounded by concrete or in the car). I have used an 800MHZ antenna which really didn't increase my reception. It sounded about the same before and after I got it. I also have tried a regular external mag mount antenna which covered all the scanner frequencies and was recommend by a scanner friend of mine who has had great results. I don't know if it was faulty or not, but I can usually pick up better in the car with my rubber ducky 800mhz antenna. I think it works sometimes then other times I just don't know. Sometimes a channel will be perfectly clear and then a few seconds later it will be terrible. My luck is terrible. This has been tried on 3 different scanners so I know that the scanners are not faulty.
So I guess my question is: Can anyone recommend a good solution. Maybe a new antenna recommendation that is a good overall all frequency antenna. I have tried the ATT button and that doesn't fix anything for anyone that things its an overload from being too close. The only place my scanner works great is in my bedroom at home. I can usually pick up everything without much interference. Outside it will usually work too just not in the car.
I'm sure no one had had the problems I have had with an antenna when they live in the same city as the towers. Right now I currently use my 800 MHZ antenna and occasionally in the car I will use the external mount, but I am constantly switching back and forth due to my paranoia of the antenna being faulty (I'm pretty sure it is).
Anyone have a good external antenna mag mount? I would like to use it in my dorm as well maybe in the room or slightly out of the window. I need all the help I can get as this can be very frustrating.
Thank you!!
Thank you!!
