I have a Uniden BCT15 scanner mounted in my Toyota Rav4 with a RadioShack glass-mounted antenna. I recently discovered I am not receiving certain frequencies while my handheld scanner and Minitor pager are. After spending hours reading articles and several different forums, I have come to the conclusion that the problem is my glass-mount antenna. So I am looking for a new antenna & mount. I do not want to drill holes to mount the antenna.
Therefore, I am considering either a hood lip mount or a roof rack mount.
I have found several from Diamond, for example:
http://www.rfparts.com/diamond/k515snmo.html
Also Larsen:
TMB or TLP mounts: http://www.larsen-antennas.com/docfiles/ASB8/Mobile/MobileIntroduction.pdf
Also Maxrad:
T Series or MT Series
http://wildcard.pctel.com/images_product_overview/pdf_docs/TSeries_PDS.pdf
Any recommendations? What is the difference between all these mounts? Is hood mount or roof rack mount better? I have read that you have to be careful about what cable you use and not to use the stock cable. Any recommendations?
I also need to buy a multiband antenna, preferably black. Do not need 800Mhz functionality. Mostly VHF (150Mhz) and UHF (460Mhz), some VHF-Low (30Mhz). Any recommendations? I have read that Larsen and Maxrad are the best...
Thank you.
Also Larsen:
Also Maxrad:
Thank you.
