2 Element Suggestion (Late)
blueangel-eric said:
I want to make a 2 element beam for use inside my apartment and i have an idea how to make the dipole and the reflector out of copper pipes but i need the spacing info and how good will it really work anyways? this is for 2meters but hopefully work for VHF and UHF for scanning.
edit: i found this
http://www.qsl.net/w4sat/tiny2.htm
last few times i looked and found nothing. anybody else have anything?
Eric Burris kc0ldt
Pardon my ignorance here, and I'm about 2 weeks late with this, but I built a three element Yagi (40" Reflector, 35" Director, and offset + / - 20" drivers on a 40" boom with an air choke), and then plugged my materials into the below site. It kicked out a model that pretty much mached what I had (except for my hairbrained idea for two drivers being offset by 0.25"). So, you might check it out, and see what it turns out.
http://www.dxzone.com/cgi-bin/dir/jump2.cgi?ID=11183
What I used, and you're going to reach a concensus here that I'm nuts, is 1/8 inch stainless steel whip (old CB antenna I came into) for the reflector and director, and I used brass welding rod for the drivers (easier to solder). It's my first attempt at anything home built as far as antennas go (everyone's gotta start somewhere, guys), and I'm generally pleased. It's 40" long, and 40 inches wide, and hangs nicely close to the ceiling from monofilament (although I've relocated it to the attic). In case you're interested, it's 16" from the reflector to the rear (-) driver, and then 21.25" from the (+) driver to the director. It's pretty crude by the standards of some of you veterans, I'm sure, but for a newbie, I was pleased to hit a tower 35 miles away on 5 watts from kitchen with lots of electronics running in that room and the living room, through which the beam had to pass to trek towards the tower. The calculated gain is only about 3.9 dB, but my SWR checked at 1.2:1. It screams "rookie," but it works.
Anyone wanting to hoot, hollar, laugh, or otherwise point out rookie mistakes (of which I am sure there are plenty), please contact me via email directly.
That's just my two cents.
73's,
Brad Parker
HA - KCØZTZ
ZA - WPVL916
