br0adband
I'm planning to use this most basic design:
http://www.pbase.com/dickh/image/27104369
and cut the leads to the middle of the bands I'm hoping to monitor - I plan to make several of these over time, actually, each tuned to a more specific frequency. The question I have is what length should provide the best signal: a 1/4 wave based on the frequency or a 1/2 wave, or one of the others listed below? I understand the basic principle that the more radiator you have the better but I'm curious as to what someone else thinks would be the best of the choices available, all easily created and cut.
Might even be able to manage 5/8 wave since we're talking about 800/900 MHz monitoring, and I plan to cut the leads to the length to tune it for ~900 MHz as here in Vegas we have a lot of 900 MHz band activity nowadays with more on the way I'm guessing. Several casinos have 900 MHz trunked systems in the 935 area, and with me monitoring so much around 855 or so I figured cutting the leads to ~900 centered would give me great coverage on either side. If that's incorrect I'd sure love to know it and know precisely why.
So, if anyone has any tips as to which length might be best, I'd love the advice. Currently lengths would be:
1/4: 3.12 inches
1/2: 6.24 inches
5/8: 7.8 inches
3/4: 9.36 inches (a possibility)
Full: 12.48 inches (a possibility)
Of those, what would most likely result in the best overall signal reception given the ~900 MHz center frequency?
1/4: 3.12 inches
1/2: 6.24 inches
5/8: 7.8 inches
