I want to feed multiple antennas into a single scanner without using a diplexer or anything else but a single bnc to double bnc adapter. Will this work? Is there any tangable benifit? Right now I am using a RS 20-176 antenna and a RS PRO-2055 scanner. Will be buying a Diamond D-130J in the near future. Using RG-58/U coax with PL-259 connectors. The antenna currently is about 30ft. or so above the ground...Also my antenna mast is not grounded to earth. Would there be any benifit other than lighting protection to doing this? Please let me know your thoughts...
