Help me figure this one out
NAVCAN
Found this antenna at work.
It's a 3 element YAGI, made by Sinclair, and has an N female connector. But I can't find any specs on it, the elements are about 6-7 inches long, and about 4-5 inches apart from each other, which tells me it's for the 450 ish MHz range.
Pics
Anyone know any specs on it?
Bentley
Freehold, NJ (Monmouth County)
Thats pretty neat...looks like the stuff you see on TV when they are tracking something. Like when someone has a transmitter and authorities are walking the streets aiming that thing in different directions trying to search out a signal. I have no clue about any specs ... sorry, just wanted to post what it reminded me of!
pappy1
Central Arkansas
that is not a 450mhz antenna, look at the driven element. It is approximately 1" long juging from the N connector size. So, what frequency has a wave link of around 2-1/4 inch? Maybe a WiFi.
NAVCAN
well...i work for the Air Navigation System of Canada, and we don't have much in the field of wifi....and yeah, the driven element is about 2 1/2 inches long.
rescue161
KE4FHH
Hubert, NC
1248 MHz
Are you sure the driven element is 2.25"? If it were 3", then it'd be a 900 MHz Yagi.
n5usr
Bethany, OK
The driven element is the entire middle element. That short piece is simply the matching stub.
If the middle element is 6-7" long (as the OP states), that would be an 800 MHz antenna (860MHz = 6.5" dipole, which is what the driven element of a Yagi is).
