Since that is a vertical VHF/UHF antenna, I would be quite surprised if they rated it using an SSB power rating - SSB is almost always run using a horizontal antenna, so is an unlikely use for that antenna. I couldn't find anything that mentioned what the rating was for, just 200W, so I would assume (which - granted - can get you into trouble at times...) that the 200W is an FM rating.
Looking at Diamond's website, they don't mention SSB/FM either - just "power" - and some are intended for repeater use (continuous duty, and FM). Just happened to have bought a Comet tri-bander recently, and the supplied instructions do note FM after the power rating, although their website does not - just lists the power. It's probably safe to assume that rating is for FM power.
