I've looked all over the place before posting this thread and please forgive me if any duplicate questions here but here's my question: I recently purchased one of the new RS Pro 164's (which I think is absolutely a wonderful scanner). As noted in the past 1,000 threads, the stock/OEM rubber ducky antenna leaves a bit to be desired. That being said, can ANYONE recommend a "normal size" (lighter weight, less than 9 inches) that would be a good overall antenna? I live in Louisville, KY and the most used bands are 180.000's and 460.000's (the ones I care about most). 800mhz or trunking is not important to me. I know nothing will beat a discone or outdoor antenna but my goal is to upgrade and still remain portable without too much stress on BNC connector (weight/height). I have tried the RS Deluxe Scanner Antenna (20-034) with no major upgrade at all. I'm not having too much of a problem but I know with this scanner, I can get better reception. I've read about the Condor, different Diamonds, etc. but have yet to run across one perfect for my situation. I prefer rubber ducky style to the extendables, if possible. Can someone please give me some recommendations and where to buy?
Thanks for your help!
