Hello everyone
Looking for antenna suggestions for work, home and mobile for use with a handheld Uniden 396T scanner.
Frequencies: Mainly scanning analog trunked systems in the 850 ~ 870 MHz range, but also scanning some conventional channels around 450 ~ 470 Mhz and 26~50 Mhz (but those are not as important). Listening range is probably a mute point, given my restrictions (outlined below) but for reference it's about a 25 mile radius in the central/north central Oklahoma City metro area. The terrain is pretty flat, with scattered tall buildings here and there in clusters. Closest primary transmitter for the trunk system that I normally listen to is roughly ~12 miles from my home location and ~8 miles from my work location.
Work: 2nd floor, office building, internal room with no windows and a covered ceiling roughly 10' ~ 12' high. However, there is about ~15' above the covered ceiling to the actual 'hard' ceiling (bottom of the 3rd floor) in which I could install something. Mounting would be easy, as there are large zig-zagging beams running across that have metal bars running at angles between the two beam that I could affix items to. However, there are florescent lights in this room, but I don't know if they would interfere with the signal or not. Room is secured, so there is no concern of other people finding/stealing the antenna.
Home: I live in an apartment on the 1st floor, has to be indoors because I have no porch or deck, or 'idle' space outside. Apartments suck...but on the plus side I don't care how large the antenna will be, or how it looks, as long as it works good. Since I can't place anything outside, my ground plane is pretty much non-existent unless I put something together.
Mobile: 4-door sedan install, it's a lease so no drilling or mag-mount. So far, considering a NMO trunk lip mount (with unknown antenna) or an Antenex low-profile antenna, like the [FONT=Arial, Helvetica, sans-serif]TRAB821/18503 [/FONT]model (shown here). However, will the low-profile antenna provide poor performance versus a normal full-height antenna? The trunk lip mount is ok, too, but the overall antenna height needs to be under 8' from the pavement to keep from hitting those damn 'low-height' bars at fast-food drive through windows and other places. Here is a picture of the low-profile antenna I was thinking about...but correct me if I'm an idiot to consider it versus a normal antenna. Either way, it must be tolerant to high wind speeds: driving ~70MPH with storm wind speeds gusting up to 50MPH = upwards of 120MPH sheering force...
Please let me know if any additional information is needed -- I know it bugs everyone when people ask questions and don't give you the information you need.
<> Thank You for your help!! <>
