mrsvensven
- Joined
- Jul 27, 2006
- Messages
- 165
I have been reading some old threads about grounding and lightning protection for antennas, and I now have my station properly grounded. I am wondering what kind of lightning protection is recommended for my roof top antenna.
I have seen links to protectors in teh $75 range, and I would definetly buy one if it is what I need, but would something like this work fine too? Right now my cable goes through a Grounding block with F connectors, so this would fit onto my coax perfectly. This protector is much cheaper than others though, so is it not going to be as reliable? I assume that I can't transmit with that protector? Is the impedence mismatch an issue (it's 50 ohm cable). Should I use one of those models on the cable TV coax entering my house (it looks like that's what it is designed for)?
If I needed a different protector, I could always cut off the F connectors and put on UHF or N connectors, so connector type isn't a huge deal.
