Which antenna do you recommend in this frequency range. Thank-You
A al95 Member Joined Jun 8, 2006 Messages 751 Location Brownsville,Texas Mar 12, 2008 #1 Which antenna do you recommend in this frequency range. Thank-You
G gcgrotz Member Joined Feb 21, 2006 Messages 2,092 Location Savannah, GA Mar 13, 2008 #2 Mobile or base? Will you be transmitting? A 1/4 wave vertical is easy to make and works good for local coverage. Many commercial scanner antennas available too, check www.dpdproductions.com or Universal Radio.
M mjthomas59 Member Joined Nov 29, 2006 Messages 510 Mar 13, 2008 #3 Depending on your needs a simple 5/8 wave or 1/4 wave VHF antenna would do the trick. The 5/8 wave will provide a little gain if you need it.
A al95 Member Joined Jun 8, 2006 Messages 751 Location Brownsville,Texas Mar 13, 2008 #4 mobile it is not for transmitting
Nasby Member Joined Apr 4, 2004 Messages 2,634 Location Ohio Mar 14, 2008 #5 Diamond RH77CA. Can't be beat!
