The Maldol AL-500H/HS whip is a thin, whippy dual-band duck for the VHF airband, and UHF milair band. Essentially, it provides a quarter wave on each band, with a small decoupling coil in the middle. It is available in both BNC and SMA versions.
While there are many other choices of improved antennas available, the one area where the Maldol shines above the rest if for what it doesn't do - namely it is a narrowly-tuned antenna with good rejection of the FM broadcast band.
This rejection may not be noticed by those in urban areas far away from FM broadcasters, or have radios with great bandpass filters. Strong FM broadcast signals don't always mean you will hear FM broadcasters in the airband(s). In my case, close to an FM broadcaster, it is as if someone turned my rf-gain down a little bit.
So I ran a test for FM rejection against the following antennas, using an Icom R6 with it's expanded S-meter:
Diamond SRH-77A
Diamond SRH320A
RS telescopic tuned to airband
OEM Uniden and RS ducks
For the test, I tuned to one of the offending FM broadcasters that overload my receiver. I attenuated the R6 so that I could actually detect a difference.
For the Diamonds and the telescopic, even with full attenuation, the FM broacaster pegged the meter. The OEM ducks were about 1/2 to 3/4 scale.
With the Maldol, the FM broadcaster varied from totally gone, to about a single flickering bar.
Recommendation: If you are in a metropolitan area, have a receiver with wide bandpass filters, or both, the Maldol comes highly recommended.
Even if you are not interested in the dual-band nature of the Maldol for milair, the FM broadcast rejection for the VHF airband makes it my top choice.
I am not sure why the Maldol is so narrowly tuned. I'm not going to cut it open to see if there are any additional tuning components inside the base. Perhaps the decoupling coil is making it narrow. I don't know. But the testing and my own listening with a variety of low-cost scanners tells me that the FM rejection is a welcome "feature".
Diamond SRH-77A
Diamond SRH320A
