| Severe Weather / Storm Chasing Forum for the discussion of severe weather radio communications and storm chasing radio communications related topics. |
07-20-2008, 05:52 PM
Problem with wx
i have a problem why isn't my weather wx picking up good it used to sound clear like this http://youtube.com/watch?v=MlygNIFsjbI this is my vid now it sounds like a snowy tv channel and you can barely hear the voice now
07-20-2008, 06:04 PM
I wonder if the transmitter is having problems, can you pick up any other WXR transmissions?, Did anything in your system change?
Here in my part of Nebraska I can hear any one of 4 wx transmitters in the area. How far are you from the transmitter?
ICOM IC-2200H, IC-2100H, 2x Bearcat III, old PRO-46, hasn't failed me yet.
I am not affiliated with any of the companies, whose links I provide, on this or any other forum.
Grid Square DN90WW
07-20-2008, 06:06 PM
morristown tennessee
the noaa radio transmitter is in morristown tennnessee i dont think it changed i can hear 2 wx transmitters but not clear at all
07-20-2008, 06:17 PM
How far are you from Morristown? Are there other systems on VHF you listen to that are acting the same way? I am trying to put pieces together to see if I can help.
Grid Square DN90WW
07-20-2008, 06:19 PM
ok
70 miles away no other vhf is acting up like this
07-20-2008, 06:35 PM
This in interesting, confirming, only the weather radio is acting up and no other systems, ok that blows one theory I had away, I wonder if the radio propagation might be the problem, given the distance from the transmitter which is really too far away (the systems are designed for about 50 miles, according to NOAA) and the band conditions which, are at least here, are different than usual, it might be a temporary thing check this evening after dark and see if it is still the same, also check in the morning, and see what it is like.
I will do some checking on propagation conditions for your area and see what I find.
Grid Square DN90WW
07-20-2008, 06:39 PM
ok
ok there is a severe thunderstorm warning in claiborne county idk if that has anything to do with it but now i hear nothing on the wx
07-20-2008, 06:48 PM
there is a transmitter in la Follette that transmitter is only 8 mi away it working again
07-20-2008, 06:49 PM
still weak
07-20-2008, 06:56 PM
I am betting on conditions wait a few hours and check again.
Grid Square DN90WW
07-20-2008, 06:57 PM
ok
ok ill wait and see
07-22-2008, 07:26 PM
I sent you a pm, did the wx rx straighten out?
Grid Square DN90WW
