I use National Weather Radio stations to assess how well one antenna works compared with others. It's a great tool for checking out your radio & antenna in a new house or hotel....
You may need a better antenna than the antenna provided with your scanner. The metal telescoping or short multi-band antennas don't give you the best signal, if listening remotely. Check out the other forums or do a search for "antenna," as needed.
A weather radio (or wx-alert enabled scanner) should be as mandatory, for any home owner or renter, as a smoke/CO detector and a fire extinguisher......IMHO.
Enjoy the new scanner!!!
