This can be done with a Minitor pager as well.
As for keeping the radio muted until the signal is decoded, there should be a squelch or unmuting setting somewhere where you select the "and" setting instead of the "or" setting. Basically, the radio will look for BOTH the subaudible (PL) tone AND the two-tone before the radio unmutes. If the channel is set for CSQ, it will just look for the two-tone.
Matt
"If the tallest building in your county is a grain silo, you DON'T need 800mhz!"
