Go Back   The RadioReference.com Forums > Topic Specific Forums > Severe Weather / Storm Chasing
Severe Weather / Storm Chasing Forum for the discussion of severe weather radio communications and storm chasing radio communications related topics.
Old 09-30-2009, 10:23 PM
Default Scan All 7 Weather Frequencies With 1050 hZ
Does anybody know what equipment, if any, would allow me to scan all 7 weather channels with 1050 hZ decode? There have been times when I have been traveling that I have thought it might be handy to scan all of the weather channels and hear an alert on any of them. One of my concerns, however, is that with 7 channels to step through, might it miss an alert as it is stepping through the other channels. If anybody has tried this I would like to hear from you.
Old 10-01-2009, 04:48 AM
You can do this with an XTS2500 or XTS5000 using single tone. NOAA transmits the 1050hz tone to 8 seconds, which is more than enough time for the XTS to scan all 7 channels, even when all 7 wx channels have traffic. In my area I can hear 5 WX stations, when a VHF band opening happens, I can hear all 7.
Old 10-02-2009, 03:37 AM
Chauffeur6's Avatar
First off, spending $1200+ on an XTS for weather alerting is a bit overkill. Secondly, even if someone did want to spend that much, exactly how is the radio supposed to scan 7 different frequencies that all have a constant carrier? It'll lock on one frequency and never move off it as long as it detects a carrier. Unless /\/\ has secretly implemented some type of "silent scan" ala the Minitor V, it's just not going to work the way you describe.
Old 10-21-2009, 12:16 AM
Ray_Air's Avatar
I think he means he just wants the radio to open up if it detects the 1050Hz signal. In essence, it is just scanning for the 1500Hz tone. That's the only way it would work, if it is doable. It would have to be like a Minitor.
Ø
Motorola Systems Saber Net
0249AF6AB3915CD2
Old 11-01-2009, 10:44 AM
burner50's Avatar
Bob Loblaw
Send a message via AIM to burner50 Send a message via MSN to burner50
Wirelessly posted (MINE!!!!11!!oneone: BlackBerry9530/5.0.0.328 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
Some Yaesu amateur hear does this
Jason
Moderator / Iowa Database Administrator
burner50@radioreference.com
Rules and guidelines for forum post content
Old 11-01-2009, 11:31 AM
UPMan's Avatar
Uniden Product Manager
When investigating the operating methodology for a line of portable WeatherRadios we were developing (not my current "we" but a previous "we"), we talked extensively with the weather service in regards to whether this (scanning for a tone) would ever be needed. The upshot was "no." If you are ever in an "overlap" area (where multiple NWS transmitters have overlapping coverage) and that area requires a warning, the warning will be sent on all transmitters with coverage, to ensure that any consumer in that area tuned to any one of the multiple frequencies would be alerted.
The test site used in the DFW area is just south of Denton, and can receive three different NWS transmitter sites. We actually had to special request the NWS to stagger each transmitter by 5 minutes when we were testing so that we had time to reset all radios to the next transmitter frequency (otherwise, they triggered them all at basically the same time for the weekly test).
Got a question? Ask it in a public forum for faster response.
My solar power station
Old 11-01-2009, 01:08 PM
fmon's Avatar
Code:
Alpha tag      FIPS Code  Event Alert Tone
Virginia       *51***	  ***	Default
West Virginia  *54***	  ***	Default
Kentucky       *21***	  ***	Default
My scanners are set as above.
Frank
RR Wiki Programming Shortcuts
Old 11-01-2009, 02:38 PM
Michael-SATX's Avatar
Default Partial FIPS codes *** ?
FMON - OK, I'm curious .... one doesn't program "astericks or wildcards" as a FIPS code right ?
So I am guessing that you do use the full 5 digital SAME FIPS code for your county ?
You probably just didn't include all 5 digits for your county in the off chance a newbie accidently
enters "your numbers" instead of "their numbers" .... and thus misses their own NOAA Alerts right ?
Frank & Paul, as usual, your technical explanations have taught me a lot and I am sure others agree !
Michael
Pro-106, 164, 96, 95, 92, 83, iCom-R3
Pro-2067, 2055, 2052, 2017, BC-350-A
Grundig YB-400PE, Radio Shack DX-396
RS 20-043, RS 20-176, RS 20-283's/HH's
