Go Back   The RadioReference.com Forums > Topic Specific Forums > Severe Weather / Storm Chasing
Severe Weather / Storm Chasing Forum for the discussion of severe weather radio communications and storm chasing radio communications related topics.
Old 09-01-2012, 11:29 PM
Default NOAA Alert Radio on Repeater
Hello Folks.... have a question here. Does anyone have a Weather Alert Radio linked into there repeater. We have a 70cm repeater that we use for SKYWARN and wanted to look into getting a alert when there is weather alert put out for the 3 counties we service.
THOUGHTS, IDEAS, SUGGESTIONS.......................
Old 09-01-2012, 11:37 PM
bravo14's Avatar
You can try to call the Weather Service Center near you. I'm sure they have info.
Dell computers SUCK! Dude you jail you can't get a dell
Radios Alinco DJ-X10T IC-F43GT BCD396XT PSR-800
Youtube staugfl1991
Old 09-01-2012, 11:57 PM
n5ims's Avatar
There are a few area ham repeaters that have the controller programed to say "Weather Alert" when there are local warnings and "Skywarn Net" during an active net (this is similar to the ID process, but generally every 5 mins or so and only when the repeater isn't currently active). The "Skywarn Net" alert is part of the configuration when a control op uses the tones to activate the net (along with linking the various networked repeaters, changing the courtesy tone, remove the PL tone, etc.). I believe that the "Weather Alert" is initiated by the weather service either from their text service or processing of the normal weather radio's SAME codes. This does require one of the "smart" controllers, but these are pretty common nowdays.
Old 09-02-2012, 3:36 AM
gewecke's Avatar
Thumbs up
The Linker 2a will do this,
Integrated Control Systems
73,
n9zas
Old 09-02-2012, 4:22 AM
N2ACF's Avatar
I have used the CAT WX-250 for over 10 years and it has worked perfectly! Very easy to install, then set it and forget it.
WX-250 Digital Weather Receiver
Old 09-03-2012, 1:56 PM
Thanks, we knew that we would need to get a controller that allowed this but I wanted to hear from people who have this already installed and have played with it.
Old 09-03-2012, 2:56 PM
gewecke's Avatar
Thumbs up
I can give you a number to call for all the info you need on how to do this,including cost?
73,
n9zas
Old 12-21-2012, 9:41 PM
You may want to check the various product offerings from THUNDER EAGLE Thunder Eagle, Inc. - Wireless Alerting Systems
Daniel Gropper at Thunder Eagle provides great customer support and highly reliable products.
I've been using various Thunder Eagle "Weather Eagle" series NOAA Weather Radio Receivers & interfaces for several years now supporting The Weather Channel and NBC Network News.
Kevin Parrish
