The Midland WR-300 has arrived here at the Personal EOC and is ready to be placed into official operation.
I've only had it for a couple of days, so this is only a preliminary review if anybody cares about reading a weather radio review.
I haven't messed around with the AM/FM alarm clock stuff though, just the weather stuff.
The online user manual is here:
http://www.midlandradio.com/comersus...alog/WR300.pdf
When I first powered on the radio, the display showed "VERSION 5" which makes me wonder how many versions there are and what the differences are. I find that a little annoying as it gives me the same paranoia as owning a Radio Shack scanner.
The 3 LEDs blink briefly when you first power on the unit. They are nice and bright, but the tops of the LEDs don't sit just above the display surface like the manufacturer's photos show. Instead the LED's are each underneath a clear lens, which makes me wonder if that causes them not to appear as bright from across the room.
For some reason it looks better in the photos, but the backlight is dimmer than a BC396T.
PROS:
You can make the backlight stay on.
The receive sensitivity is about the same as many scanners. Last night I had it on top of the microwave and there must have been a heck of a band opening because I could hear stations doubling and tripling up on all 7 channels.
You can choose which alerts you want to receive. For example, you can make it only alert you for tornado warnings but not tornado watches, or vice-versa, or you can have both off or on.
Backup AA batteries work seamlessly like a UPS.
The radio has no automatic built-in squelch, so it will let you receive the weakest signals right down to the noise floor. Then again, you will GET that nasty noise floor if you tune to a channel not active in your area.
CONS:
For some reason, if you set the backlight to be continuously on and then you disconnect all power (both AC & batteries), the radio loses your backlight menu setting and reverts back to the default 5-second timeout. Other than that, the memory appears to non-volatile so you won't lose your settings or FIPS/SAME codes when the radio has no power.
The radio doesn't scan the weather channels. To choose which frequency you wanna listen to, you have to program it via a menu setting. You can't just simply hit the up & down arrows.
The weather channels are numbered differently than my BC396. I'm not sure which radio is wrong.
The display contrast is not as clear as a PRO-97 or a BC396, in fact it is rather dull in my opinion. Notice in the photo below how the manufacturer's photo on the box makes the display look at lot crisper than what it is in real life. Why do manufacturers always do that?
The AM/PM identifier on the clock is so small you almost a magnifying glass to see it.
The manual included with my unit says you can program 30 FIPS codes, but the radio only lets you program 23. If you choose the "ALL" alert mode to hear all alerts, the manual doesn't say if it will also alert you to the older generic 1050 kHz alerts as well as all the specific alerts.
The AC adapter cord is only 6 feet long. Why do all gadgets today always give such short power cords? It'd be nice to have a longer cord so you can move the radio around more for better reception.
So there you have it. I may add more info to this thread later.
For searches: wr300 wx NOAA NWS NWR alert severe weather wr100 wr-100
