| Shortwave Broadcast Discussions regarding shortwave broadcasters |
03-06-2009, 01:33 PM
jj130 HF antenna???
....fartin around this morning, I hooked my Diamond discone to the R75-all I can say is WOW!!! Anyone here have a J130 and a SW radio-hook 'em up and tell me what you found
EDIT: tried to take out one of the Js in the title-stupid wireless keyboard skips a lot-anyways the antenna is a Diamond J-130.
Uniden BC785D
Uniden BC350A
ICOM IC-R75
ICOM IC-R71A
dual Diamond D-130Js on the roof
...being "comfortable in my delusion"-THANKS!!
Pro 2066 in the truck with glassmount
73s-I am Frank
03-06-2009, 06:23 PM
I don't have that antenna nor radio, but I do listen to HF with my IC706mkIIg in the mobile with a 5/8 wave 2m whip. I can hear a lot without a 6ft antenna perched on the roof (that turns heads I tell 'ya! LOL).
03-07-2009, 10:03 AM
....I assume you meant to say with a 6' antenna right? That's neat stuff  I am totally amazed at how this antenna performs on SW! I have a Ham Radio Outlet catalog and on the "SW listening" page they have, along with the log periodics and longwires etc., a J130 Diamond Discone which I always thought was a scanner antenna alone-even states "for 25-1300MHZ"-so rather than call, I hooked mine up to see why they'd group it in on this page-not only do I get great reception but this antenna actually lowered the noise floor from around 15-20 down to 3-10! THAT opens up a whole bunch of new discovery!! And I dont have to kick on all the filters like before. Just thought I'd throw that one out there for those of you who have space issues but want a great HF getter
http://s295.photobucket.com/albums/m...t=MVI_0119.flv
...here is the J130 at work!
Uniden BC785D
Uniden BC350A
ICOM IC-R75
ICOM IC-R71A
73s-I am Frank
03-07-2009, 01:58 PM
I occasionally use a discone in a pinch for HF reception and it can work ok. A very small antenna can be 20-30dB or more down from a full size dipole and as long as the signals are relatively strong you can still have a similar signal to noise ratio as the larger antenna but with much less perceived noise.
prcguy
03-07-2009, 10:40 PM
prcguy
That must be what I am experiencing here. I tell you this antenna's performance suits me just fine  as you can see in my little link above-it gives me a good reliable CLEAN signal. I am surprized I haven't heard more on this.
Uniden BC785D
Uniden BC350A
ICOM IC-R75
ICOM IC-R71A
73s-I am Frank
03-07-2009, 11:35 PM
If you have a very short run of low loss coax to your discone it will help preserve signal levels on HF because of the really high impedance of the short elements at HF and the additional coax losses above and beyond the advertised coax loss.
I have a Yaesu VR5000 which is fairly sensitive but overloads quite easily with a large HF antenna. On the rare occasion I use the Yaesu its usually connected to a discone to avoid overload and reduce some of the noise this annoying little radio has on HF.
prcguy
03-08-2009, 03:33 AM
[QUOTE=ridgescan;1021984]....I assume you meant to say with a 6' antenna right? That's neat stuff  /QUOTE]
Re-phrase: I can hear plenty with the 2m 5/8 wave without having a 6 ft stick on the roof. Certainly the big antenna is better, and then I can transmit as well, but believe it or not, in spring I was copying a KH6 station from Hawaii on 80 meter CW as I drove across northern ILL using just the 2m antenna. He wasn't loud, but he was solid for 30 minutes. I'm sure with the 'real' 80 meter stick, I could have worked him.
03-08-2009, 07:22 AM
prcguy
Hey when I was ready to buy a SW it was a tossup between that Yaesu and the R75-looks like I made a good choice? The Yaesu has its attributes though I'm sure-on the coax I am running 20' of RG8X-and yeah, just like you describe in your examples, the prominent improvement is the noise floor, which now has even totally gone away in some areas of the bands! It opens up a lot more chance to grab some of those obscure DXs
[quote=k9rzz;1022659]
-sorry I should have known better  that's the really cool point here is that you can get reliable reception from an antenna that was totally designed for another spectrum. How big is that 2M antenna?
Uniden BC785D
Uniden BC350A
ICOM IC-R75
ICOM IC-R71A
73s-I am Frank
03-09-2009, 02:29 AM
It's fifty four (54) inches. Certainly no slouch itself, but you should see that big 80 meter stick perched up on the roof, it's a head turner.  Hmmmm, maybe I'll take a few pictures today and post 'em.
