Go Back   The RadioReference.com Forums > HF / MW / LW Monitoring > Shortwave Broadcast
Shortwave Broadcast - Discussions regarding shortwave broadcasters
  #2021 (permalink)
Old 10-24-2017, 10:29 AM
[QUOTE=Boombox;2824537]^^^^^^ Yes and no. I've been using the same indoor antenna since 2011, and used to pull in a *lot* more SW than I do now. Especially Radiobras (Amazonia) -- conditions had to be abysmal for it not to come in.
What indoor antenna are you using?
  #2022 (permalink)
Old 10-28-2017, 6:09 PM
Glenn Hauser's World of Radio on 11.580 khz 2300z to probably 2330z.
  #2023 (permalink)
Old 01-07-2018, 9:44 AM
ridgescan's Avatar
Fantastic conditions here on a Sunday morning-a shot of the good old BBC transmitting at a little over 11,000 miles from Talata-Volonondry, Madagascar on 12095kHz. I love Winter propagation!
https://youtu.be/VQbTKyCZhZU
BC785D to Diamond D130J @50'
IcomR71A, RS DX-160 to Wellbrook loop @50'
IcomR75,
'54 SX-88 #127 to 100' endfed wire/9:1 trans. @40'
RS Pro 2066 in truck to Larsen Tribander
  #2024 (permalink)
Old 01-07-2018, 1:17 PM
Originally Posted by dragon48 View Post
It's a 25-30 foot wire that is folded back on itself and runs in a rough L, in the second story of the house. So It might be longer than 25-30 feet... But that's probably its effective length. I put it up after I began to get re-interested in SWL and Ham listening in 2011. On SW I've used it with my DX-398, 390, and 440.
PS Sorry for the late reply... Didn't notice it until just now.
  #2025 (permalink)
Old 01-15-2018, 2:29 PM
Voice of America in English & Korean. 9975khz Target: Korea at 2030UTC. Clear skies here, about 250 south of Anchorage. Best signal quality I've heard in a year.
  #2026 (permalink)
Old 01-15-2018, 2:38 PM
ridgescan's Avatar
Nice catch! Getting it here too @ +10-+20 over 9. Transmitting from Udan-Thani, Thailand. 15580kHz VOA is also strong from Botswana at 2042UTC. s7-9.
IcomR75,
  #2027 (permalink)
Old 03-27-2018, 11:30 AM
mbott's Avatar
Started the morning on RNZI with a good signal into central Ohio on 7425. With the rain, my noise floor was down about 20dBm and my QRM less than 95% of normal. Love the rain.
2 Star Roamers ICF-2010 ATS-909X IC-R75 & IC-7300 PL-660 R-1000 & R-5000 FRG-7 RSP2 & RSPduo HF+ NRD-535D GP-5/SSB RF Pro-1B ALA1530LNP
  #2028 (permalink)
Old 03-29-2018, 11:29 AM
c_snyder's Avatar
I've been receiving radio saudi from riyadh pretty well here in northern indiana on 13710, 15205 and 15435 during the day. About a month ago I installed a new mini whip outside on the south wall of my office building and i'm very impressed with how well it works.
  #2029 (permalink)
Old 03-29-2018, 11:57 AM
ridgescan's Avatar
Elaborate upon the "mini whip" brand so others know exactly what antenna impressed you they may want to get one too!
IcomR75,
  #2030 (permalink)
Old 03-29-2018, 1:19 PM
c_snyder's Avatar
I don't know if it has an exact brand name but I purchased it on ebay from a seller in London. He sells both assembled units and kits you can put together yourself but it appears his assembled listings are out of stock right now. If you search for "IP33 mini whip" you should find a listing for it.
Here's a link to his website. On that page is a link to a document that describes the specs and has some assembly instructions.
OE1GPA mini whip
The entire setup consists of this mini whip connected to 60 feet of LMR 195 that goes back to my office about 40 feet away. As most of you probably know these antennas are very susceptible to noise and it took me the better part of two weeks to find a setup that worked well. Inside it did not perform well at all but I wasn't surprised as the building is covered in steel siding on all sides. I ended up putting it outside on the south gable end of the building just mounted on a wall mount about 13 feet above ground.
I still had a lot of interference traveling back to the antenna on the coax so I had to address that as well. I ended up running the cable through a ferrite core about eight times where it enters the building and then again three times in the office where it connects to the receiver. The difference was night and day, the noise floor is nice and flat now. I do think the steel siding also helped in keeping interference inside the building away from the antenna.
This is all connected to a $20 version 3 rtl receiver running in direct sampling mode. It works better than I thought however there are a lot of spurs everywhere and the signals are aliased above and below 14.4 mhz. This is just due to the rtl dongles sampling at 28.8 mhz. I did order a proper HF receiver last night, I wanted to wait until I got everything sorted out on the antenna side.
  #2031 (permalink)
Old 03-29-2018, 2:40 PM
ridgescan's Avatar
OE1GPA mini whip
That's great info! One more thing, if you would, can you specify what ferrite core (composition) you are using? This would complete the picture for those who may want to give your setup a go Thanks!
IcomR75,
  #2032 (permalink)
Old 03-29-2018, 6:33 PM
c_snyder's Avatar
The ferrite close to the antenna is a fair-rite model 2631626202. It’s a 31 mix that’s 25.4 mm inside, big enough that you can put about eight turns on it with the 195 cable. Inside the office at the receiver I transitioned to about two feet of lmr100 and a fair-rite 2631102002 12.8 mm inside diameter ferrite. It’s just the right size to get three turns on it with the lmr 100.
I ordered these from mouser and you do have to pay shipping but if you order multiples or other things it’s not too bad. Some people have luck with the ft-240-31 ferrites but in this case I had too much interference and needed the bigger one. It’s quite impressive how much interference there is in a house / office!
  #2033 (permalink)
Old 03-29-2018, 9:11 PM
ridgescan's Avatar
The ferrite close to the antenna is a fair-rite model 2631626202. Itís a 31 mix thatís 25.4 mm inside, big enough that you can put about eight turns on it with the 195 cable. Inside the office at the receiver I transitioned to about two feet of lmr100 and a fair-rite 2631102002 12.8 mm inside diameter ferrite. Itís just the right size to get three turns on it with the lmr 100.
I ordered these from mouser and you do have to pay shipping but if you order multiples or other things itís not too bad. Some people have luck with the ft-240-31 ferrites but in this case I had too much interference and needed the bigger one. Itís quite impressive how much interference there is in a house / office!
Thanks for all this. Honestly I personally needed to know about the ferrite cores-I might get them for my Wellbrook.
IcomR75,
  #2034 (permalink)
Old 03-29-2018, 9:22 PM
mbott's Avatar
I've dealt here without complaint.
Ferrite Products for RF Chokes, Baluns, and RFI Mitigation
  #2035 (permalink)
Old 04-20-2018, 11:21 AM
1505 UTC
5980 Radio New Zealand in English
Heard loud and clear in Kodiak, AK, nice clear cold morning with my Tecsun PL660, no external antenna needed.
  #2036 (permalink)
Old 07-08-2018, 9:05 AM
04:35 UTC 16 June 2018
Logged and recorded Radio Saudi on 15170 - short video of it posted on YT at https://youtu.be/wsGsgLGfkKA
Probably my longest DX copy, was solid reception for almost an hour with no fading - logged several others on the same band but this is the furthest one of the bunch so I wanted to share it
