Go Back   The RadioReference.com Forums > HF / MW / LW Monitoring > Shortwave Broadcast
Shortwave Broadcast Discussions regarding shortwave broadcasters
Old 10-11-2009, 02:59 AM
CLynch7's Avatar
Default 5810 0655z ???
On 5810 I'm getting a decent signal of a phone ringing, its been ringing for at least the last five minutes. NASWA log doesn't show anyone using this frequency right now, WEWN signed off almost 2 hours ago.
.....and it just stopped ringing 0658z, still strong carrier w/ open mic.
Chris, KJ4MPT
Radio Shack Pro-51, Pro-75, Pro-83
Grundig G5, G6 Aviator, TRII Digital
GE 7-2990A, Kenwood TH-78a Dual Band
Old 10-11-2009, 07:57 AM
scottaschultz's Avatar
Arrrrgh matey! Sounds like it may be a pirate!
Scott - NĜIU
Old 10-13-2009, 03:43 PM
k9rzz's Avatar
I'm not so sure it's a pirate.
I heard the same thing this afternoon but on about 15,200 khz (roughly) using my Eton FR-350. I was sitting at a park bench tuning around when I heard the phone ringing. The signal was LOUD. Not 100 watts loud, but 50kw or more loud. Then I heard some kind of Caribbean music for 30 seconds, then three sets of 5 letter morse code groups, and then back to phone ringing. I wanted to get the exact frequency, so I walked to my car and tuned around on the mobile (Yaesu FT706mkIIg) and _could not find_ them. I tuned from 16mhz down to 5mhz and could not find it despite having it still on the Eton!!
I suspect an image on my reception, but I have no idea where it was from.
Old 10-19-2009, 01:40 AM
k9rzz's Avatar
Just happened to catch them just as I turned on my Eton. Five letter code groups and I could hear the phone ringing in the background. Approx. freq. is 5810khz. It's the SW1 band at the left of the dial. How easy is that for a spy to tune in?
Old 10-23-2009, 01:48 AM
brandon's Avatar
This station is active each night around the same time.
Right now it's about 20 over S9 here into southern California. I usually hear CW then then an open carrier follows with ringing in background. I'm also hearing some data or intentional jamming mixed in. Here is an audio clip of the ringing w/ data sounds. Last week I was able to hear voices below the carrier, and NO they were not in my head!
Old 10-23-2009, 10:07 AM
k9rzz's Avatar
Something's going down.
Old 10-23-2009, 01:36 PM
The signal in Your record is DIGTRX. It is easily defined by baud rate ~122.5 and by quantity of channels=8.
In Your record baude rate is very close to this value and quantity of channeles is also 8.
Manipulation mode in the channel is DPSK-9 - it is the special differential original mode with manipulation of the phase. The signal is not OFDM, but the classical multichannel transmission. The attached picture shows parameters of the signal in Your record. That's detailed discription of DIGTRX signal Signals Analysis: DIGTRX is the very interesting signal. Fresh analysis..
p.s
i have suspections that you had made this record throught microphone. This is not correct for the digital signals.
http://signals-analysis.blogspot.com/ -my blog : all about signals identification and analysis.
Old 10-23-2009, 01:46 PM
brandon's Avatar
Hi Maria
I take the recording from the Line Input. The quality might be low because its saved as MP3 format. This was recorded in AM mode and the humming is actually in the signal, not from the computer. Do you know how I can make it better quality? I am not familiar with decoding digital signals other than HFDL and ALE. I will check again tonight as it seems to be active around 0500-0700 UTC.
Old 10-23-2009, 01:54 PM
Sure, i can be mistaken about microphone.
There is the short but effective advices about how to make a good record:
Signals Analysis: Record for the following analysis.
Hope You will find them usefull.
Best regards.
Old 10-26-2009, 12:15 AM
DX-300's Avatar
Interesting haha...I was just about going to post about this when I saw someone else is on this already! ...I just heard this morse code thing going on last night at around 12ish am and around that same time I wanted to tune to something else and I stumbled upon a numbers station on 5882 kHz going on and on in spanish with that VERY ringing in the background!!!
Old 10-26-2009, 01:33 AM
Heard this last night 0600-0700 on 5810. I am hearing the same thing right now 0530 on 5898
Edit now hearing it all again on 5800 0600 UTC
Old 10-26-2009, 07:56 PM
kb2vxa's Avatar
Check out the Cuban numbers lady in the utility listening forum, we have a parallel discussion here.
73 de Warren
Amateur Radio KB2VXA
Station powered by atomic energy, operator powered by natural gas.
