Go Back   The RadioReference.com Forums > HF / MW / LW Monitoring > Shortwave Broadcast
Shortwave Broadcast Discussions regarding shortwave broadcasters
Old 05-29-2010, 10:59 PM
CalebATC's Avatar
Send a message via AIM to CalebATC Send a message via Skype™ to CalebATC
Default Looking to get into shortwave
Hi,
I'm looking to get into shortwave, but I don't know much about it. I'm a VHF and UHF man
What good recivers are there, and what are the prices?
I am looking to monitor USB, and some of the 5.XXXX frequencies for Miami Oceanic.
Student Pilot | Amateur Radio General K-4-C-N-G
Monitoring from 30 KHz to 1.2 Ghz, Operating 80-70cm
Old 05-29-2010, 11:29 PM
k9rzz's Avatar
Dude. That's like saying: "I want to listen to the police. What should I buy?"
For starters, how much money do you have to spend?
General Coverage Receivers - The RadioReference Wiki
Old 05-29-2010, 11:36 PM
Wiki Admin Emeritus
You can start your research by looking at our HF Gateway in the wiki...
HF - The RadioReference Wiki
Read the stuff in the preamble - they will give you some of the basics, which you will need to understand to get started. It's especially important to understand the basics of HF Propagation. Unlike scanners, there are bands that open only at night, and those open during the daytime.
At the bottom, you will find a link for equipment and accessories. That article has LOTS of links to reviews, articles and so forth. Sad to say there aren't many HF desktop radios anymore - the Palstar is one of the very few, along with the Icom R75 workhorse. Look around and see what strikes your fancy. Ask questions - you'll find lots of places for answers. If you're a ham, or looking to be one, an used HF transceiver (which nowadays often has a built in HF general coverage rx) may be another option. There are even some online HF receivers you can play with.
73 Mike
Old 05-30-2010, 12:06 AM
CalebATC's Avatar
Well, that's what I'm asking. Around how much are the recivers? How much are the antennas?
I'm looking to monitor USCG and anything else I can find, along with flight communications. And Miami Oceanic, along with all the other oceanic frequencies.
Old 05-30-2010, 6:01 AM
Wiki Admin Emeritus
Antennas aren't all that expensive, especially if you've got some leftover coax from your scanner antenna stuff - in fact you can build one quite cheaply (well south of USD50, less if you've got stuff in your junkbox)
As for receiver prices - that depends greatly if it's new (for example, see some of the links at Universal Radio) or used, as well as your own budget. Keep an eye out for the various hamfests in your area, and I wouldn't ignore some of the used radio links at places that actually check out a radio before it's put on the list (like Universal Radio's used list). You'll pay a bit more, but you will also get a return policy - something you're not likely to find on places like eBay or Craigslist. You will pay less if you get a used rx. The same rule applies to ham transceivers - say a Kenwood TS440, or one of the older Yaesu models. Heck, even the FT817 QRP radio I had for a time had a helluva hot general coverage rx.
73 Mike
Old 05-30-2010, 10:29 AM
CalebATC's Avatar
Alright- Thanks alot, the recivers are pretty expensive though. Looks like I'm gonna wait a while.
Old 05-30-2010, 11:16 AM
If youre willing to use your computer as an interface TenTec manufactures an awesome receiver.
The RX-320D....
Old 05-30-2010, 11:28 AM
Wiki Admin Emeritus
And don't forget about the various online radios linked at the bottom of the HF article 73 Mike
Old 05-30-2010, 11:33 AM
CalebATC's Avatar
Yes- That's where I ordered my ST-2, they are all over $700. A little over my price budget
Old 05-30-2010, 11:48 AM
nova1010's Avatar
Send a message via Yahoo to nova1010
Thumbs up
You can buy the best SW receiver out there but if you haven't got a good antenna it might as well be a brick.
Get yourself a good inexpensive sw receiver that does USB/LSB to start off with and a good antenna and your good to go.
Im using a DX-398 with a Kaito KA35 active loop antenna indoor because im in an apartment works good for what I want to listen to.(I paid around $125 used for my setup)
If your in a house and able to throw a good line outside do it.
Good luck.
The only thing necessary for the triumph of evil......is for good men to do nothing.
Old 05-30-2010, 11:50 AM
Wiki Admin Emeritus
If you look at the Universal website that lists used radios, there are a few there that are well south of USD700. For example, there's the FDM77 (that's a Software Defined Radio or SDR), an Icom R70 and used R75, a Kenwood R2000 and a Yaesu FRG100. All of them floating around the USD400 range.
Murstech is quite right - the RX320D is a fine performer in its own right, but in many ways the FDM77 is better. The RX320D new is retailing for USD369 but with a little patience a used one can be had for less. In both of these cases, though, you end up marrying a PC to a radio. They don't work stand-alone.
Take the time to read the various reviews and links supplied earlier and educate yourself. That doesn't cost anything, and you'll learn something about what to look for and what to avoid. 73 Mike
Old 05-30-2010, 1:32 PM
CalebATC's Avatar
Alright gents,
Thanks for your help!
I'm only 13 so to come past that much money is a little hard. Atleast I know what to look for now when I goto buy one.
What do you get on HF and USB besides aviation, and USCG? I know there is globaltalk and Link11, but thats it.
Old 05-30-2010, 1:55 PM
Wiki Admin Emeritus
<sigh> Again go read the HF wiki article I gave earlier. It gives a good introduction into all the things you can hear. It only touches a little below the surface, but it's a real good starting point....73 Mike
Old 05-30-2010, 2:24 PM
brandon's Avatar
Hi CableATC
I would recommend subscribing to the HFmonitors group. It's the best HF monitoring group out there for us folks in the United States. The owner actually lives in Flordia, so his reception logs be a good reference to see what you can expect to hear.
There is another excellent group called UDXF but it tends to focus more on Europe.
solarix.net - ScanRiverside
Old 05-30-2010, 2:33 PM
CalebATC's Avatar
Alright, thanks Brandon.
And will do Mike.
I am a member in FL Milcom, so I get emails from him occasionally.
Thnaks.
Old 05-30-2010, 2:43 PM
nova1010's Avatar
You can also register here GlobalTuners - On-line remotely controlled tuners and have a listen
Old 05-30-2010, 3:00 PM
CalebATC's Avatar
Alright, thanks.
Old 06-06-2010, 9:05 AM
csoguy's Avatar
My Yupiteru MVT-7100 is a portable multiband receiver and it does pretty well for shortwave. It does very well for shortwave when hooked up to an external antenna. They are very hard to find as they were discontinued many years ago, but well worth the investment if you can find one. I bought mine from the UK...cost me under $200 shipped. Yupiteru was not a brand offered here in the states so they are all unblocked models. I am thinking about getting a ICOM IC-R20 but it needs to be as sensitive in the shortwave range and not sure if there is anything to listen to above 1650mhz!?!
Van Buren County Feed Provider
http://www.radioreference.com/apps/audio/?feedId=2790
Old 07-20-2010, 6:29 AM
Default thanks!
73 Mike
Thanks for the info mike, ill take time to read it so i too can better understand it. I've been a vhf/uhf guy for pushing 30 yrs now. And I too have my eye on shortwave. I live monitoring the feds and a buddy told me to check into this. I dont have the license to Tx so i am looking to Rx only. And being a novice im on a budget as well. I want to monitor FBI,DEA,BORDER PATROL,COAST GAURD, as well as Military. I noticed Radio Shack has a Grunding G5 and a Grunding 750. Are these good models to start out with and have the necessary coverage range that i am looking for?
thanks
jb
(2) 996-XT w/GPS &RH , 396-XT ,UNIDEN BC-142XLT
(2) RS PRO-106, RS PRO-197, RS PRO-2055 W/ RAMSEY
PUXING PX888 W/ SCRAMB, YAESU FT-250, WOUXAN KG-UVD1P, ICOM 2200H W/ UT-110 SCRAMB
GRUNDIG S/W,
Old 07-20-2010, 8:21 AM
rexgame's Avatar
Location: Drexel Hill, Upper Darby Twp, Delaware Co, Pennsylvania, USA-Close enough?
Send a message via AIM to rexgame Send a message via MSN to rexgame Send a message via Yahoo to rexgame
USB and LSB are both examples of SSB modulation. The analog passbands are AM, SSB, QAM, FM, PM, and SM.
Most of the military stuff is either AM or SSB in the HF range (though, any frequency can have any modulation). So just check to see if the radio has SSB. I just got a G6 for the road, and at the house I use a CCRadio-SW. The CCRadio (also known as KAITO KA2100 and REDSUN RP2100), does not do SSB however, for around $30 you can add a little device (called a BFO) that will plug into the IF out and allow you to do SSB,
