Voice of the People
Token
Which freq did you catch? They and their sister station The Echo of Hope are in here every morning.
3480, 3912, 4450, 6518, and 6600 are all VOP freqs I have logged in the past. Quite often they are heavily jammed by the NKs.
T!
Mohave Desert, California, USA
(edit) Just checked and 6600 and 6518 are in right now (0535 UTC). No sign of them on the other freqs, but it is a little early to have conditions that low.
(2nd edit) Brain fade, it is the Echo of Hope, not the Voice of Hope as I first wrote. And its freqs are 3985, 6003, and 6348.
bryan_herbert
Las Vegas, NV. DM26jc
All of their freqs were active around 0745 UTC yesterday. 6518 and 6600 were being jammed by what sounded like DRM. The other freqs though were clear.
Token
I checked all the VOP and EOH freqs this morning (16 Jan UTC) and was very surprised to find the lower VOP freqs untouched by NK jammers.
VOP on 6518 and 6600 had their old companion jammers in attendance, and all three of the EOH freqs, 3985, 6003, and 6348, were also jammed. But, 3480, 3912, and 4450 were completely in the clear for VOP. That has been a rare event in the past. I wonder if the NKs are having a problem with their low band jammers?
T!
Token
Checked again this morning (Jan 17, 2011, 1445 UTC) and only two freqs are in the clear, 3480 and 4450. All others for both VOTP and EOH are being jammed. However the 3912 jammer appears low in power and less affective than usual.
T!
