The RadioReference.com Forums
-   Shortwave Broadcast (https://forums.radioreference.com/shortwave-broadcast/)
-   -   Pirate YHWH loggings (https://forums.radioreference.com/shortwave-broadcast/278688-pirate-yhwh-loggings.html)
Token 11-24-2013 8:01 PM
Pirate radio station YHWH is up on 6150 kHz, AM mode, at 0110 UTC. S9 or a little better here, audio is much improved over what it was several months back.
T!
ka3jjz 11-24-2013 8:24 PM
In the middle of the 49mb?? Or is that a typo? Mike
Token 11-24-2013 8:49 PM
Nope, not a typo, he was on 6150 kHz. This pirate moves around and hits none traditional pirate freqs, often in a BC band. He has worked in the more traditional (for US pirates) 69XX kHz range a few times, but not often. He signed off at 0241 UTC this round.
T!
kilokat7 11-25-2013 8:24 AM
Here are some recent audio clips that I captured while I was remotely connected to Token's Perseus SDR. This station's carrier was detectable here in Michigan with only threshold audio at times (such as during the interval signal).
6075 kHz AM YHWH 23NO13 0228-0232 UTC.mp3
6150 kHz AM YHWH 25NO13 0120-0148 UTC.mp3
ka3jjz 11-25-2013 9:04 AM
And I saw a couple of logs reported from the West Coast in the DXLD Yahoo group
k9rzz 11-27-2013 7:12 PM
How can they be heard over the 50 to 100kw regulars? Something is amiss here.
Token 11-28-2013 12:07 AM
Not sure what you mean by “amiss”. He finds an unused freq between the BC stations and goes at it. For example when he was on 6150 he was between Radio Romania Int on 6145 kHz, and Voice of Iran on 6155 kHz. Neither of those stations were particularly strong on the west coast at that time, so his signal fit right in. Since he appears to be using a ham rig his audio is not quite as wide as the BC stations. His audio is about 3 kHz wide, maybe a bit over that.
T!
ka3jjz 11-28-2013 6:02 AM
Not at all - it's exactly the same techniques used to find the Columbian, Mexican or Brazilian stations on 49 meters during the 'height' of the hi power stuff time-wise, and Token touched on it. You become familiar with the band during a particular slice of time, and make like a gopher and dig. Eventually you will be able to identify most of the big-power stations on their regular freqs - this makes the stations like this one stand out like a sore thumb (although I will say that putting a pirate in the middle of 49m during the evening is either crazy or smart - it's called hiding in plain sight).
49m is quite a challenge to DX during the 2200-0200 time block here on the East Coast because that's when the Euros and Cuba tend to dominate. But even then you can find stuff - heck I think there's still some Africans around the 2200-0000 time frame.
k9rzz 11-28-2013 9:51 AM
Is this another one of the wanna be disc jockeys or someone with REAL programming content? Certainly, it would be nearly impossible to get any sort of following by frequency hopping all over the place.
Token 11-28-2013 10:22 AM
Did you hear the audio clips kilokat7 posted? That is this guys programming content, he is very consistent about his format. Maybe not my cup of tea but he obviously feels strongly enough about his message to get it out this way.
Despite hopping around he obviously is being reported regularly. I have no idea how the ratio of his transmissions vs reporting is. I don’t look for him often, I spend little time inside the SWBC bands, but when queued to his activities I have always been able to hear him.
T!
k9rzz 11-28-2013 1:15 PM
Okay, I broke down and listened to part of one clip.
#Yawn
k9rzz 11-28-2013 2:05 PM
More loggings: "Strange pirate radio Radio YHWH" 9775
Token 03-29-2014 2:01 PM
Pirate YHWH, 21450 kHz, USB, 03/29/2014, 1830 UTC
Pirate radio station YHWH, with his standard message, on 21450 kHz, USB mode, 1830 UTC, March 29, 2014.
YHWH is in USB this time. It almsot seems he uses AM when near BC bands, and uses USB when near ham bands.
T!
Token 04-18-2014 10:52 AM
Pirate YHWH, 17490 kHz, AM, 4/18/2014, 1516 UTC
Pirate radio station YHWH, Yahweh, on 17490 kHz UTC. The station came on air at 1516 UTC, but I did not notice it until 1531 UTC. About S9 here, and being reported across the US, not heard on European remotes that I can tell.
This pirate is located in the US south west.
(edit) Station signed off at 1621 UTC.
T!
Token 04-19-2014 7:18 PM
Pirate YHWH, 29130 kHz, USB, 2357 UTC, 4/20/2014
Pirate radio station YHWH on air at 2357 UTC, 29130 kHz, USB, April 20, 2014. Signal is S8 here.
T!
Token 07-19-2014 10:49 PM
Pirate YHWH, 9600 AM, 0331 UTC, July 20, 2014
Pirate radio station YHWH signed on at 0331 UTC with his normal intro music. Live operator on the mic for the first several minutes before going into his standard recorded programing. S9+ here in the Mojave Desert of California.
T!
QDP2012 07-19-2014 11:27 PM
Interesting pirate call-sign. Do you think the broadcast is make from in-country or out-of-county?
Token 07-20-2014 12:28 AM
The operator claims to be transmitting from a "remote location in the desert, in the US South West".
T!
Token 07-20-2014 4:57 PM
Pirate YHWH, 15655 kHz, AM mode, 2151 UTC, July 20, 2014
Pirate station YHWH up at 2151 UTC, July 20, 2014, with intro music on 15655 kHz, in AM mode. S9 here in the Mojave Desert.
(edit) Off 2306 UTC.
T!
Token 08-20-2014 12:14 PM
Pirate YHWH, 15655 kHz, AM, August 20, 2014, 1702 UTC
Pirate station YHWH up with intro music at 1702 UTC, August 20, 2014, on 15655 kHz, AM mode.
Up with his normal recorded show.
(edit) Off 1757 UTC.
T!
