HFDL frequency updates needed
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
We have a table of HFDL frequencies (also referred to as HF ACARS) in our wiki at:
HFDL - The RadioReference Wiki
along with links to software that can copy this mode. Unfortunately I don't belong to the HFDL Yahoo group, and the table there is from Jan 2008 - which makes it a bit dated. Does anyone have the updated list of frequencies, along with the correct system table and timestamp?
Please pass that info along so I can update it. 73 Mike
psr600md
Green Bay,WI
see the map it has all the hf freqs if you need it bigger pm me w a email
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Thanks but those aren't HFDL related - these are MWARA frequencies- basically en route frequencies used to report positions, and obtain selcalls. A totally different animal.
I have applied the updates to the HFDL article, thanks to Bill and the MT forum.
73 Mike
SCPD
QRT
Virginia
DB 43:
Version 43
Ground Station ID 1
SAN FRANCISCO - CALIFORNIA
UTC UNLOCKED
Longitude 121 45 34 W Latitude 38 22 48 N
Squitter Version 0
Number of frequencies 8
Frequency 21934000 Hz Master Frame Slot 4
Frequency 17919000 Hz Master Frame Slot 12
Frequency 13276000 Hz Master Frame Slot 8
Frequency 11327000 Hz Master Frame Slot 4
Frequency 10081000 Hz Master Frame Slot 4
Frequency 8927000 Hz Master Frame Slot 12
Frequency 6559000 Hz Master Frame Slot 8
Frequency 5508000 Hz Master Frame Slot 4
Ground Station ID 2
MOLOKAI - HAWAII
UTC UNLOCKED
Longitude 157 10 46 W Latitude 21 10 47 N
Squitter Version 0
Number of frequencies 12
Frequency 21937000 Hz Master Frame Slot 0
Frequency 17919000 Hz Master Frame Slot 7
Frequency 13324000 Hz Master Frame Slot 3
Frequency 13312000 Hz Master Frame Slot 3
Frequency 13276000 Hz Master Frame Slot 3
Frequency 11348000 Hz Master Frame Slot 11
Frequency 11312000 Hz Master Frame Slot 11
Frequency 10027000 Hz Master Frame Slot 11
Frequency 8936000 Hz Master Frame Slot 0
Frequency 8912000 Hz Master Frame Slot 0
Frequency 6565000 Hz Master Frame Slot 7
Frequency 5514000 Hz Master Frame Slot 7
Ground Station ID 3
REYKJAVIK - ICELAND
UTC UNLOCKED
Longitude 21 50 59 W Latitude 64 4 47 N
Squitter Version 0
Frequency 17985000 Hz Master Frame Slot 11
Frequency 15025000 Hz Master Frame Slot 7
Frequency 11184000 Hz Master Frame Slot 3
Frequency 8977000 Hz Master Frame Slot 0
Frequency 6712000 Hz Master Frame Slot 11
Frequency 5720000 Hz Master Frame Slot 7
Frequency 3900000 Hz Master Frame Slot 3
Frequency 3116000 Hz Master Frame Slot 3
Ground Station ID 4
RIVERHEAD - NEW YORK
UTC UNLOCKED
Longitude 72 38 22 W Latitude 40 52 47 N
Squitter Version 0
Number of frequencies 7
Frequency 21931000 Hz Master Frame Slot 1
Frequency 17919000 Hz Master Frame Slot 9
Frequency 13276000 Hz Master Frame Slot 5
Frequency 11387000 Hz Master Frame Slot 1
Frequency 8912000 Hz Master Frame Slot 9
Frequency 6661000 Hz Master Frame Slot 5
Frequency 5652000 Hz Master Frame Slot 1
Ground Station ID 5
AUCKLAND - NEW ZEALAND
UTC UNLOCKED
Longitude 174 48 35 E Latitude 37 1 10 S
Squitter Version 0
Number of frequencies 6
Frequency 17916000 Hz Master Frame Slot 12
Frequency 13351000 Hz Master Frame Slot 8
Frequency 10084000 Hz Master Frame Slot 4
Frequency 8921000 Hz Master Frame Slot 12
Frequency 6535000 Hz Master Frame Slot 8
Frequency 5583000 Hz Master Frame Slot 4
Ground Station ID 6
HAT YAI - THAILAND
UTC UNLOCKED
Longitude 100 23 24 E Latitude 6 56 23 N
Squitter Version 0
Number of frequencies 9
Frequency 21949000 Hz Master Frame Slot 10
Frequency 17928000 Hz Master Frame Slot 6
Frequency 13270000 Hz Master Frame Slot 2
Frequency 10066000 Hz Master Frame Slot 10
Frequency 8825000 Hz Master Frame Slot 6
Frequency 6535000 Hz Master Frame Slot 2
Frequency 5655000 Hz Master Frame Slot 10
Frequency 4687000 Hz Master Frame Slot 10
Frequency 3470000 Hz Master Frame Slot 6
Ground Station ID 7
SHANNON - IRELAND
UTC UNLOCKED
Longitude 8 55 46 W Latitude 52 43 48 N
Squitter Version 0
Frequency 11384000 Hz Master Frame Slot 2
Frequency 10081000 Hz Master Frame Slot 2
Frequency 8942000 Hz Master Frame Slot 6
Frequency 8843000 Hz Master Frame Slot 6
Frequency 6532000 Hz Master Frame Slot 10
Frequency 5547000 Hz Master Frame Slot 2
Frequency 3455000 Hz Master Frame Slot 6
Frequency 2998000 Hz Master Frame Slot 6
Ground Station ID 8
JOHANNESBURG - SOUTH AFRICA
UTC UNLOCKED
Longitude 28 12 35 E Latitude 26 7 46 S
Squitter Version 0
Number of frequencies 5
Frequency 13321000 Hz Master Frame Slot 6
Frequency 8834000 Hz Master Frame Slot 10
Frequency 4681000 Hz Master Frame Slot 2
Frequency 3016000 Hz Master Frame Slot 2
Ground Station ID 9
BARROW - ALASKA
UTC UNLOCKED
Longitude 156 46 46 W Latitude 71 18 0 N
Squitter Version 0
Number of frequencies 19
Frequency 21937000 Hz Master Frame Slot 10
Frequency 21928000 Hz Master Frame Slot 10
Frequency 17934000 Hz Master Frame Slot 6
Frequency 17919000 Hz Master Frame Slot 6
Frequency 11354000 Hz Master Frame Slot 2
Frequency 10093000 Hz Master Frame Slot 2
Frequency 10027000 Hz Master Frame Slot 2
Frequency 8936000 Hz Master Frame Slot 10
Frequency 8927000 Hz Master Frame Slot 10
Frequency 6646000 Hz Master Frame Slot 6
Frequency 5544000 Hz Master Frame Slot 2
Frequency 5538000 Hz Master Frame Slot 2
Frequency 5529000 Hz Master Frame Slot 2
Frequency 4687000 Hz Master Frame Slot 2
Frequency 4654000 Hz Master Frame Slot 2
Frequency 3497000 Hz Master Frame Slot 10
Frequency 3007000 Hz Master Frame Slot 10
Frequency 2992000 Hz Master Frame Slot 10
Frequency 2944000 Hz Master Frame Slot 10
Ground Station ID 11
PANAMA - PANAMA
UTC UNLOCKED
Longitude 79 32 59 W Latitude 8 58 12 N
Squitter Version 0
Frequency 17901000 Hz Master Frame Slot 6
Frequency 13264000 Hz Master Frame Slot 2
Frequency 10063000 Hz Master Frame Slot 10
Frequency 8894000 Hz Master Frame Slot 6
Frequency 6589000 Hz Master Frame Slot 2
Frequency 5589000 Hz Master Frame Slot 10
Ground Station ID 14
KRASNOYARSK - RUSSIA
UTC UNLOCKED
Longitude 92 18 0 E Latitude 56 6 0 N
Squitter Version 0
Number of frequencies 10
Frequency 21990000 Hz Master Frame Slot 4
Frequency 17912000 Hz Master Frame Slot 12
Frequency 13321000 Hz Master Frame Slot 8
Frequency 10087000 Hz Master Frame Slot 4
Frequency 8886000 Hz Master Frame Slot 12
Frequency 6596000 Hz Master Frame Slot 8
Frequency 5622000 Hz Master Frame Slot 4
Frequency 4679000 Hz Master Frame Slot 4
Frequency 2905000 Hz Master Frame Slot 12
Frequency 2878000 Hz Master Frame Slot 12
Ground Station ID 13
SANTA CRUZ - BOLIVIA
UTC UNLOCKED
Longitude 63 7 46 W Latitude 17 40 11 S
Squitter Version 0
Frequency 21997000 Hz Master Frame Slot 3
Frequency 17916000 Hz Master Frame Slot 11
Frequency 13315000 Hz Master Frame Slot 7
Frequency 11318000 Hz Master Frame Slot 3
Frequency 8957000 Hz Master Frame Slot 11
Frequency 6628000 Hz Master Frame Slot 7
Frequency 4660000 Hz Master Frame Slot 3
Ground Station ID 16
AGANA - GUAM
UTC UNLOCKED
Longitude 144 48 0 E Latitude 13 28 11 N
Squitter Version 0
Frequency 13312000 Hz Master Frame Slot 5
Frequency 11306000 Hz Master Frame Slot 1
Frequency 8927000 Hz Master Frame Slot 5
Frequency 6652000 Hz Master Frame Slot 1
Frequency 5451000 Hz Master Frame Slot 9
Ground Station ID 15
AL MUHARRAQ - BAHRAIN
UTC UNLOCKED
Longitude 50 39 0 E Latitude 26 16 12 N
Squitter Version 0
Frequency 21982000 Hz Master Frame Slot 1
Frequency 17967000 Hz Master Frame Slot 9
Frequency 13354000 Hz Master Frame Slot 5
Frequency 10075000 Hz Master Frame Slot 1
Frequency 8885000 Hz Master Frame Slot 9
Frequency 5544000 Hz Master Frame Slot 5
Frequency 2986000 Hz Master Frame Slot 1
Ground Station ID 17
CANARIAS - SPAI
UTC UNLOCKED
Longitude 15 23 23 W Latitude 27 56 59 N
Squitter Version 0
Frequency 21955000 Hz Master Frame Slot 4
Frequency 17928000 Hz Master Frame Slot 12
Frequency 13303000 Hz Master Frame Slot 8
Frequency 11348000 Hz Master Frame Slot 4
Frequency 8948000 Hz Master Frame Slot 12
Frequency 6529000 Hz Master Frame Slot 8
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Thanks Nick. I haven't had a chance to get to the HFDL group so this is helpful. Next week I'll print these off and make the changes in the wiki article...best regards..Mike
SCPD
QRT
Virginia
Mike,
Here's a quickie Excel chart I've done up for Database 43:
Feel free to use it as you wish.
  • hfdl.zip
SCPD
QRT
Virginia
Here's a picture for everyone else:
SCPD
QRT
Virginia
And of course, they just moved up to DB 47 this past week. :evil:
Version 47
Ground Station ID 1
UTC UNLOCKED
Squitter Version 0
Ground Station ID 2
MOLOKAI - HAWAII
UTC UNLOCKED
Squitter Version 0
Ground Station ID 3
REYKJAVIK - ICELAND
UTC UNLOCKED
Squitter Version 0
Ground Station ID 4
UTC UNLOCKED
Squitter Version 0
Ground Station ID 5
UTC UNLOCKED
Squitter Version 0
Ground Station ID 6
HAT YAI - THAILAND
UTC UNLOCKED
Squitter Version 0
Ground Station ID 7
SHANNON - IRELAND
UTC UNLOCKED
Squitter Version 0
Ground Station ID 8
UTC UNLOCKED
Squitter Version 0
Frequency 13321000 Hz Master Frame Slot 2
Frequency 8834000 Hz Master Frame Slot 6
Frequency 4681000 Hz Master Frame Slot 10
Frequency 3016000 Hz Master Frame Slot 6
Ground Station ID 9
BARROW - ALASKA
UTC UNLOCKED
Squitter Version 0
PANAMA - PANAMA
UTC UNLOCKED
Squitter Version 0
UTC UNLOCKED
Squitter Version 0
UTC UNLOCKED
Squitter Version 0
UTC UNLOCKED
Squitter Version 0
AGANA - GUAM
UTC UNLOCKED
Squitter Version 0
CANARIAS - SPAIN
UTC UNLOCKED
Squitter Version 0
SCPD
QRT
Virginia
Mike, here's the latest Excel spreadsheet:
Changes were to Thailand, South Africa and the Russian stations.
  • hfdl.zip
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Of course they moved - they knew you were watching, hi
I can't download anything at work, but the text listing you have there is fine. It's just a matter of sitting down and making the corrections - which shouldn't take all that long
thanks...Mike
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Nick what I think I will do instead of the hard-coded table in the wiki, I'll take your spreadsheet and upload it.
Do you have the system table file the registered version of PC-HFDL uses for decoding? I can add that to the zip archive - it would be useful for other PC-HFDL users.
TIA..Mike
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Gracias Nick - I'll take care of this tonight after I finish errands
best regards..Mike
D
DaveNF2G
Guest
The latest system table (pchfdl.dat) is also available in the Files area of the HFDL Yahoogroup.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Yep, here you go:
DB 47 --> Comcast
I moved this thread to the digital forum since that's what HFDL is...
Nick, I am getting a not found when I try this URL, and I can't open the spreadsheet (.xlsx) file with Excel 2003 - did you use Office 2010 or something else to make this?
best regards...Mike
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
OK great. Did you use Office 2010 to create that spreadsheet? My 2003 version of Excel won't open it.
Thanks in advance...Mike
