Go Back   The RadioReference.com Forums > HF / MW / LW Monitoring > Shortwave Data Decoding
Shortwave Data Decoding - Discussions regarding decoding digital signals on the HF bands, including HFDL, ALE, RTTY, CW, and others.
Old 02-08-2012, 7:32 AM
IanWraith's Avatar
Default Rivet Build 18
Hello All
I have just uploaded build 18 of Rivet to Github ..
https://github.com/IanWraith/Rivet/downloads
This new build has much improved decoding of the Russian Naval mode CIS36-50.
Regards
Ian
Old 02-08-2012, 4:05 PM
zl2taw's Avatar
cheers Ian, will have a look when I get a chance
73's Doug
Kenwood R-5000 / Elad FDM-S1 SDR / Wellbrook ALA-1530 / various software decoders
Brisbane, Australia, UTC+10
Old 02-09-2012, 7:11 AM
Wiki Admin Emeritus
Ian has asked that bug reports should go to the UDXF Yahoo group...
UDXF : Utility DXers Forum
best regards..Mike
Old 02-10-2012, 4:36 PM
Cool
Ian,
Could you possible give us a 30-second tutorial on how to even run this java program? I have the Java runtime (for Windows) installed.
Old 02-11-2012, 9:43 AM
IanWraith's Avatar
Yes no problem. First make sure you have Oracle Java and if not download it from ..
java.com: Java + You
and reboot then go to ..
Click on the words "rivet_b18.jar" save the file that downloads in a folder. Next go into that folder and double click on the file after you have done that after a few seconds the program should run.
If the program doesn't run there appear to be two causes ..
1) An unzip type program has been installed which has decided that .JAR files are associated with it. If this is the case you need to change the properties of the file so it is "owned" by Java.
2) Sometimes some versions of Internet Explorer decide when downloading .JAR to automatically unpack the contents. I'm not sure how to fix this other than suggesting you use the Firefox or Chrome web browsers.
Hope this helps
Ian
Old 02-11-2012, 6:15 PM
Cool
Ian,
Thanks. I am of the old school DOS days and JAR was an older (and now obsolete container format) and that is where my confusion lies.
Now I get it.
It's running fine.
Old 02-12-2012, 5:47 AM
IanWraith's Avatar
Now I get it.
It's running fine.
That's good news. Glad I could help.
Ian
