Go Back   The RadioReference.com Forums > HF / MW / LW Monitoring > Shortwave Data Decoding
Shortwave Data Decoding - Discussions regarding decoding digital signals on the HF bands, including HFDL, ALE, RTTY, CW, and others.
Old 04-09-2016, 10:31 PM
Default Looking for windows 7 morse code decoding software
Right now, I've got a pretty low-tech way to capture morse code. I use my iPhones built in app - Voice Memos, to record morse signals directly from my radio. I then have the option of emailing myself the sound clips.
Can somebody direct me to some good (hopefully free, but I'll consider paying a small price) software that can decode the signals from the audio files.
I found some programs on the net, but they require a Mic to capture the signals and I don't have one.
Old 04-09-2016, 10:36 PM
krokus's Avatar
Have you checked if they will take an input from Virtual Audio Cable?
Sent via Tapatalk
Old 04-10-2016, 1:22 AM
I believe fldigi may be able to do this and it's free - W1HKJ Software
Ryan
BC780XLT, BC796D, BCT15, BCT15X, BCD396XT, BCD996XT, PRO-2006, PRO-37, PRO-652, Electra Bearcat II, III, IV, 8, SDRplay
RTL-SDR v.3, NooElec Mini2+, IC-R71A, IC-R75, DX392, Hallicrafters SX-100
Old 04-10-2016, 6:34 AM
Wiki Admin Emeritus
Yes, I think FLdigi will do it (on a PC), however...
Most programs that say they decode CW have a hard time when a different style of sending (hams call it a 'fist') is being used. In addition, any noise or propagation issues might fool the decoder
That being said, I understand CW Skimmer is excellent .....
DX Atlas: Amateur Radio software
co-author, HF Digital Decoding
Old 04-10-2016, 5:36 PM
I use FLdigi... it is not perfect, but it works fairly well on fairly strong signals. It also decodes many other digital modes.
IcomIcR20
Old 04-13-2016, 8:37 AM
Sent via Tapatalk
I believe that with the hardware abstraction layer being where VAC resides, and does it's dirty work, that any program that requires a mic will accept input from it. The only exception I can think of is some awful, one-off which was hardcoded to look for a particular input.
Old 04-13-2016, 11:47 AM
[deleted]
Old 04-13-2016, 12:03 PM
Wiki Admin Emeritus
Using FLDigi outside of the ham bands will have rather limited usefulness, as the modes hams used aren't used elsewhere (for the most part). MultiPSK and Sigmira are 2 very fine programs that handle lots of different modes, including morse code
See the link in my sig for the links to these packages...Mike
Old 05-29-2016, 1:21 PM
Dantian's Avatar
VOA Radiogram uses those modes outside of the ham bands. FLDigi is what they recommend, at least during this phase of the experimental program.
Old 05-29-2016, 3:13 PM
Wiki Admin Emeritus
True, but it isn't the only package that can cover both modes...this is a little OT here, as the original post was about copying morse code (CW).
Back on topic, please...Mike
Old 05-29-2016, 3:20 PM
I think I was running CW Skimmer a few years back during my fairly brief foray into HF.
As I recall, it allowed me to copy quite a few simultaneous CW conversations at once. Pretty nifty.
No, I will not program your radio for you. No, I will not give you any software. Don't ask unless you want a rude answer.
Old 05-29-2016, 3:48 PM
majoco's Avatar
Why not learn morse code using the Mk1 earhole? Works much better than any software when the going gets tough.
Old 02-05-2017, 12:32 PM
GB46's Avatar
I use HamScope for monitoring amateur CW, and also for maritime bulletins from KPH in San Francisco at 8.942 Mhz. Weak and fading signals may produce gibberish, of course. The software works through a PC's soundcard; just connect your receiver's audio output to the mike input on the PC, preferably through the radio's tape recording jack, if available.
The program is also good for amateur RTTY, for which you need to download MMTTY and place its .EXE file in HamScope's program folder.
