SDS100 First impressions!
wise871
N.W. Florida
I saw that also. What’s the hole for?
jonwienke
More Info Coming Soon!
VA
It's the passthrough for the wiring for the external GPS dongle.
jasonhouk
Uniden AlphaMan
Uniden Representative
Marion, Ohio
It's to vent the steam, NO MORE SOGGY WAFFLES!
Sent from my Moto G (4) using Tapatalk
Cheeseburgers
Any word on that syrup firmware update? i want to make sure that it heats it to 130 degrees on the nose. Paul, thoughts?
Sent from my Pixel 2 using Tapatalk
ur20v
The Feds say my name hot like when the oven on
NOVA
That antenna appears to have a bad case of Peyronie's...
Well, it has been around since the Clinton era... coincidence? Let's ask Monica Lewinsky.
wise871
N.W. Florida
Ok, I looked at the picture on the other link and it has a screw installed. Does the final version have it or just the hole. Not sure if the pic on the other link was a test model.
captainmax1
Florida Keys
A couple of my 800MHz RS antenna's look like that also but still work great. I was able to score 20 of those antenna's for $5 each when my local Radio Shack closed.
jasonhouk
Uniden AlphaMan
Marion, Ohio
No screw on production units we were advised.
Houk
KE4ZNR
Radio Geek
Yep. I have had a couple of them since the Pro-96 days and they still work great even with a little bend to them. I also have a few VHF-UHF rubber ducks that I can swap them with should I need better coverage in those ranges.
Marshall KE4ZNR
bob550
Albany County, NY
You're making assumptions. Even if something is heavily shielded, enough of a strong signal from a high-power transmitter nearby can get in through the antenna connector for a sensitive receiver to pick up a signal. It depends on exactly how powerful the transmitter is, the radiation pattern of the antenna on the tower, and the exact distance to the tower. Crappy shielding is not the only possible explanation.
That theory could be verified by grounding the antenna input to see if the signals are still received.
ur20v
NOVA
TailGator911
Silent Key/KF4ANC
Fairborn, OH
SMA/BNC adapters are notorious for damaging SMA antenna connectors if there is any bend or strain on the connection. That RS antenna looks a little top-heavy on the adapter there, also wondering about the water-resistant antenna seal gasket and if it is still employed once after market antennas are connected via adapter? Is it a seal only with the stock antenna, or is the gasket inside the main port and seals once a fitting (adapter) is tightened? Just curious...
JD
kf4anc
TailGator911
Silent Key/KF4ANC
Fairborn, OH
The buttons on the keypad look to be slightly raised from the operating platform, if so, I love the keypad layout and the fact that they are lighted! Also, there is a pronounced little knob on the '5' button - what is that for? A reference point like a calculator? Again with the curious questions hah....
