  #1 (permalink)
Old 02-17-2017, 5:35 AM
Question Painting an antenna
hi
i have build a 4G lte yagi antenna with cooper
and to prevent copper corrosion i will use non conductive spray paint
does spray painting an antenna have any impact on the signal quality ?
thank you
Sponsored links
  #2 (permalink)
Old 02-17-2017, 9:20 AM
ChrisABQ's Avatar
Default
I don't believe it does, but I would use a clear coat rather than paint.
__________________
BCD436HP w/ProVoice & DMR - BCT15X - UniTrunker DSD+ - Pro-2011(my very first radio) - Baofeng UV-5R
  #3 (permalink)
Old 02-17-2017, 9:46 AM
Default
It can, especially if the paint has conductive ingredients. Minimize the thickness of the paint or clearcoat layer to minimize potential effects on performance.
  #4 (permalink)
Old 02-17-2017, 9:55 AM
Default
You can test the paint you plan to use. Spray a decent amount on a piece of cardboard. Let it dry completely. Place in microwave and if it does not heat up, your good to go. It has to be dry(cured) before you test it !
  #5 (permalink)
Old 02-17-2017, 10:47 AM
Default
Thank you very much for the information
Sponsored links
  #6 (permalink)
Old 02-17-2017, 12:04 PM
Default
I've painted probably 100 VHF and UHF antennas and have never seen a problem. I've even tested Ku and Ka band satellite feed radomes with various spray paints and some have very little effect with just one coat. Others attenuate a lot, but painting a plastic radome is a little different than painting a metal antenna.
One thing that does happen is a coating of paint or anything on a metal antenna will cause it to resonate slightly lower in frequency because you are going from a bare metal radiator to one that has a dialectic coating. Its the same effect when going from a bare wire antenna for HF compared to using insulated wire and the effects from that can be several inch differences in wire lengths.
I'm not sure if you will notice on a small Yagi but on long lengths of wire its very noticeable.
prcguy
  #7 (permalink)
Old 02-17-2017, 11:04 PM
Amateur Radio Operator
Amateur Radio
Default
Use Krylon paint. It doesnt affect RF.
  #8 (permalink)
Old 02-22-2017, 5:32 AM
Default
ok now my antenna is painted with a thin coat of non-conductive paint (abro white)
and no difference in performance....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright 2015 by RadioReference.com LLC Privacy Policy  |  Terms and Conditions
