hello... i know this is going to sound like a pretty simple question to most of you, but here goes.
i have a BCT8 that i programed with ARC8. had no troubles getting the scanner to accept the programing from the PC...
the trunk system i have programed in works great, but i'm having trouble with one issue... getting into trunking mode.
sometimes it scans the trunking system, and then it will stop. it will scan the bank that the trunk is in, but wont stop on those frequencies.
"trunk" is displayed, along with the "active" banks that i want to scan, but it does not seem to be in trunking mode. pushing "srch" (search) and it goes to searching the preset band blocks. if i push "trunk" the trunk display goes out, then i press it again it comes back, but i'm still not able to get the scanner into trunking mode so that i can "ID search" or "ID scan"
is there a trick or series of button presses i need to use?
i'm starting to feel like tearing my hair out
