MAJOR Update for TK-x180 series radios
Do you think Kenwood will start making MDC-1200 an option on future radios?
  • Yes
    Votes: 29 80.6%
  • No
    Votes: 4 11.1%
  • Don't Know
    Votes: 3 8.3%
  • Total voters
    36
Muhlenberg County, KY
Well, Kenwood has finally done it. The TK-x180 series radios got a firmware/software update that allows the user to program it for MDC-1200 signalling. You no longer have to install an optional board. I wonder how many of the radios Kenwood will firmware/software update for MDC-1200.
n3obl
Ø
PA
I like it. just updated the firmware on some radios i had that i could not use for work because of no mdc.
Wish they had a way to change the sidetone on the radio but that more of a personal preference.
Frank
To my knowledge, the TK-x180 series and TK-5x10 P25 series radios are the only ones that have been upgraded to do MDC-1200. Surely with the TK-2170 being a newer model radio only a few years old, they will upgrade it as well to do MDC-1200.
Funny thing is the Nexedge radios won't do MDC-1200 yet. So, who knows.
pddispatcher
Trying to get my 2180 to accept the 921E Checksum firmware.
I put the radio in Firmware programming mode by pushing S and turning on at same time.
It displays PROG 115200
Open Fpro.exe, find the .HEX file and push Write. Program acts like it is writing but the radio does nothing.
Still showing the old checksum as well and yes, I do have the correct COM Port selected.
Thoughts?
try switching the programming speed to the next slower speed. be carefull with programming the new firmware in i heard that it older radios it may fry the cpu
pddispatcher
Got it adjusted the rate to 19200 and it accepted it fine and then imported the information from the 7180 to the 2180 and had a fully programmed radio in 5 minutes.
Captain715
Columbia, PA
Might it be possible for someone to drop me a copy of the current firmware? Also, what is the current version of the KPG89D software, I am running 1.60.
ramal121
Lots and lots of watts
Calif Whine Country
KPG89D is current at v1.60
Firmware for X180 is now listed as F1FF (v1.20).
Update states "Applied "baud rate guard" for MDC-1200".
I have firmware zip.
I would like a copy as well.
My local Kenwood dealer has turned into an A-Hole. He wants to charge me 100 bux just to do one radio, and I've got 5 of them.
so they figured out the problem with the baud rate settings between fleetsync and MDC-1200, eh? I thought it was kinda funny when my tech programmed his radio for the MDC-1200 right after getting the 921E checksum firmware and his radio wouldn't encode/decode MDC-1200. Because the Fleetsync baud rate was set for 2400 when he switched over, the MDC-1200 ran at a baud rate of 2400. Can you imagine the kind of mass hysteria that would be brought on if a few ran MDC-1200 at 2400?!?
sseawright
Poplar Bluff, MO
MDC not a channel signaling option after firmware upgrade.
I have just upgraded my TK-7180 with the latest firmware, it shows the sumcheck 921E in the radio display. In the 1.6 software I am now using, I changed the model information signaling type to MDC1200. When going to the menu, it now shows a menu item for MDC1200, but when editing the channel information, MDC1200 does not show up as an option. Only DTMF and the different 2-Tone options. Any help that you could throw my way would be great appreciated. Thanks.
kf6owc
Sparks NV
F1FF Firmware
Can anyone send me the F1FF firmware. I am trying to upgrade my 2180 so I can use the TFS feature. I currently have Version 1.14 but I cant seem to figure out how to change the options in the radio. I have been able to figure out were to do that at. KPG-89D does have it so I figure upgrading the firm ware might work????
Email w7owc AT att DOT net
code3cowboy
CA-CZU
I would dig a copy of that firmware. You will need the current version of the programming software to get everything to work.
