Conventional MPA Programming Software
wspicer
LaGrange KY
I'm am trying to find where I can buy a copy of the programming software for a 16 channel conventional UHF MPA and can't find it anywhere if anyone knows of somewhere I could get it please let me know...Thanks
mm
oregon
if you can handle the older DOS software on a older 486 PC then it's simple to setup and get going, simply go to the yahoo ge groups and join.
In the file section you will find the MPA dos software.
GE : GE@Yahoogroups.com
If you need programming equipment go to price industries and look at the P96 program box and the MPA1 cable or just the MPA2 serial cable.
Price Industries
If you don't have an old 486 style PC and want to run the dos software from a fast PC then go to the DOSBOX webpage at Main Page - DOSBoxWiki and you can use the dosbox software to run the MPA dos program from a fast windows XP or similar PC.
I have programmed many conventional and EDACS MPA's and MPD's with the Price industries box's and cables using dosbox on a 2.4 GIG xp machine and never had a problem but remember your mileage may vary depending on your PC.
Mike
