Boy this thread went south quick. To the OP, you need to be more specific on what you want programmed per say. P7100's can only do so much depending on features enabled. Also this thread should serve notice for anyone else asking for radios to be programmed, be Smart. Programming a radio for receive only is as harmless as having a scanner, but may raise some eyebrows though if you make a scene about having one. If you want to talk, you need a valid reason to, and authorization from the licensee, and will further more refer you to the Radio Shop. Dont expect someone online to be an accessory.
