I've had my Pro-95 for 3 years now and have used it daily in my car, non-stop. Recently, my trunked banks stopped working. The scanner would not stop on any freq.... just scanned continuously. After switching to manual on each freq I noticed the there WERE transmissions, but very garbled. After much thought and many days of troubleshooting I decided to run the search feature between 850mHz and 860mHz... To my surprise, the scanner began stopping on freqs, with voices coming in loud and clear. After analyzing the freqs and writing them down (including the control freqs, which I've come to recognize their tones through the years) I realized that ALL the freqs which were being stopped on were EXACTLY .0125mHz (12.5kHz) higher than the normal ones. For example if a control channel was previously 858.9375, my scanner now heard it on 858.95. Once I realized this, I ran a little test and re-programmed all the voice channels (untrunked) into a bank and lo and behold, they all worked... at +.-0125. So I decided, hey, maybe if I reprogram my 4 control channels at +.0125 then I'll be back in business... Well, no go. The scanner DID trunk successfully at that point (it DID resolve the control freqs to voice freqs and the IDs began to show up) but the freqs they were resolving to were the original ones (which I now have to add .0125 in order to hear them).
So my question is...is there any way I can retune this band DOWN .0125mHz so I can be re-calibrated? Maybe like one of the small pots inside the unit? Any advice will be much appreciated. Thanks very much.
