...and part II:
17-Jun-2010 11:03:45 Connection complete to Icecast server audio3.radioreference.com/906914778
17-Jun-2010 15:08:40 Write to Icecast server failed Unable to write data to the transport connection: An established connection was aborted by the software in your host machine.
17-Jun-2010 15:08:40 Disconnect details follow (for debugging if necessary
Message: Unable to write data to the transport connection: An established connection was aborted by the software in your host machine.
Source: System
TargetSite: Void Write(Byte[], Int32, Int32)
StackTrace: at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size)
at ScannerCast.ScannerCast.PushClientThread()
--Message: An established connection was aborted by the software in your host machine
Source: System
TargetSite: Int32 Send(Byte[], Int32, Int32, System.Net.Sockets.SocketFlags)
StackTrace: at System.Net.Sockets.Socket.Send(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags)
Socket error: 10053
17-Jun-2010 15:08:50 Connection complete to Icecast server audio3.radioreference.com/906914778
17-Jun-2010 16:17:11 Write to Icecast server failed Unable to write data to the transport connection: An established connection was aborted by the software in your host machine.
17-Jun-2010 16:17:11 Disconnect details follow (for debugging if necessary
Source: System
Source: System
Socket error: 10053
17-Jun-2010 16:17:22 Connection complete to Icecast server audio3.radioreference.com/906914778
17-Jun-2010 20:28:18 Write to Icecast server failed Unable to write data to the transport connection: An established connection was aborted by the software in your host machine.
17-Jun-2010 20:28:18 Disconnect details follow (for debugging if necessary
Source: System
Source: System
Socket error: 10053
17-Jun-2010 20:28:28 Connection complete to Icecast server audio3.radioreference.com/906914778
17-Jun-2010 22:29:18 Write to Icecast server failed Unable to write data to the transport connection: An established connection was aborted by the software in your host machine.
17-Jun-2010 22:29:18 Disconnect details follow (for debugging if necessary
Source: System
Source: System
Socket error: 10053
17-Jun-2010 22:29:28 Connection complete to Icecast server audio3.radioreference.com/906914778
